Results 1 to 5 of 5
Thread: Ride quality - XJR6
    Aug 2008
    Southampton
    Ride quality - XJR6
    Morning all,
    Just a quick question I have, not really a concern but I wanted to see what the general opinion is.
    I've just taken my XJR6 in for what will no doubt be a very expensive service! As a courtesy car, the specialist has given me an old XJ40; I think it's a a base-model 3.2. I've noticed, of course, that the ride quality is significantly better than the XJR's. I put this down to the XJR's sports suspension and low profile tyres, but I was just wondering - should the ride in a comfort-spec XJ40 be so superior to a sport-spec XJR? I mean, the XJ40 has the sort of ride quality I was expecting from a Jag; the XJR doesn't ride much better than my 1994 Honda Accord. Is this right? Should I be concerned? I did test drive a few XJRs and I found most of them had a pretty firm ride, so I'd assumed mine was OK, but I really just wanted to see if anyone else has had the same thoughts as me!
    Alex
    http://img.photobucket.com/albums/10...ig0908copy.jpg
    1995/M Jaguar XJR /// Don't Dream It... Drive It!
    Senior Member L80OUS's Avatar
    Aug 2006
    Lincoln
    Re: Ride quality - XJR6
    Quote Originally Posted by Capri
    Morning all,
    Alex
    Hi
    The ride quality being better than a XJ40 could just be down to your own personal preference, but when you mentioned 94-reg Accord I have to reply. There is no chance on this earth the ride between your XJR and the honda should be anywhere near close. I think you have some serious problems if this is the case.
    The only car I have ever driven which was a nicer quality ride than my XJR8 was a Bentley Arnage T.
    Maybe you could explain why your XJR is such a bad ride, in what ways?
    XJ X351, XJR X350, S-Type 2.7D Sport, XJR X308, X-Type 2.5 Sport, XJ X300 Sport
    Aug 2008
    Southampton
    Well, it's just not very wafty lol. I've noticed that transmission of imperfections in the road surface is worse than in the XJ40 I drove, and it tramlines more too. I also notice bad potholes make it crash a little bit. On the motorway it gets much better, although you can still feel expansion gaps through the steering and suspension more.
    I mean, I know that the XJR6 will be a lot more harsh riding than the XJR8 due to its lack of CATS, and not as good as a standard XJ due to its stiff setup and low profile tyres. It's not really any worse than the other XJR6s I drove but I just wanted to see if anyone else has felt this way, or if it's just me being paranoid! I genuinely don't mind if this is the way it's supposed to be (I don't mind the firm ride as a payoff for its remarkable handling) but I just want to verify that it is!
    Feb 2008
    Surrey
    What size wheels are on both? from a standard XJ on small wheels to an XJR on large wheels you will notice a difference. There is always a trade off between handling and comfort.
    Bottom line Capri if you are happy with it I wouldnt worry about it.
    2008 08 XF 2.7d Premium Luxury in Midnight over Charcoal with Rich Oak vaneer and ALL the options bar the sunroof.
    Aug 2008
    Southampton
    Craig - many apologies for the belated response on this one. I think it was just a touch of the 'expensive repair' paranoia!
