Results 1 to 6 of 6
Thread: Exhaust gas/smoke leak from engine?
    Nov 2007
    Hi all,
    I was driving down an A road yesterday; rapidly increased speed to overtake (reached about 85mph). When I came to slow moving traffic I started to see smoke from under the bonnet which also started coming inside through the vents.
    Luckily I was right near petrol station to pull over. I lifted the bonnet, the smoke appeared to be coming from a mesh looking pipe underneath the engine (windscreen side end).
    Any ideas as to what might be happening? I'm sure it wasnt radiator/coolant fluid, as the temp gauge seemed normal.
    Incidently, I continued driving at at steady 50mph for another 25miles odd and there seemed to be no problems.
    Any help/advice would be great.
    Thanks.
    '99 Jaguar XJR - Black with Ivory interior
    Nov 2007
    Just in case anyone wants to know. i took it to a jag specialist and there seems to leak from the gearbox sump gasket- seems to leak on the pipes which was causing the smoke
    Aug 2008
    South Wales
    Hope it wasn't too expensive!
    This one goes to 11
    Nov 2007
    I've not had the work done yet - next week. It's estimated at a couple of hundred (parts and labour)- apparently the XJR uses a particularly expensive gearbox oil (which apparently is different to the one used for XJ8s).
    No terminal damage to engine/gearbox so it's not too bad.
    Jul 2007
    Kent
    The 4.0 V8s used the Mercedes box and the special ATF fluid costs a fortune (£23 per litre !) from a Jag main dealer, £10 a litre from Mercedes and less if you buy 20 litres from a direct oil supplier. Ask if you can buy the oil , look up the posts on XKR/XJR gearbox oil changes and buy it cheaper else where ?
    1998 XKR Convertible, 2004 S-type V8 SE
    Nov 2007
    Ah yes, I remember reading about sharing the gearbox with Mercs...
    I'll just let them get the oil; how many litres would it need anyway??
