Results 1 to 5 of 5
Thread: Remove Radio/ cd drive
    Jan 2010
    I have a 2003 X type with a touch screen and I need to remove the radio/CD unit under it to get at the wiring.
    Can some one point me in the right direction.
    Rex
    Senior Member Prod Eng's Avatar
    Jan 2008
    Sunny N.W
    Re: Remove Radio/ cd drive
    Take off the gear surround(pull up gently), remove the two screws retaining the ash tray, take off the cigar lighter wiring. At the very bottom of the stack you may or may not see a blank plate underneath, behind this are two screws and the other two are behind the bezel surrounding the hazard warning switch.This again is a gentle pull off removal. Stack is then pulled forward and out.
    2l Petrol, Retro fit=Sat Nav,PwrFold,Rr Park Aid,Full Lthr,Htd Frt Scrn,Rr Splr,Clear Side Repeater's,18"Aruba's,2 Cup Console,Heavy Chrome Pack,Twin Round Tailpiece,Red Caliper's,Rr Pwr Window's,Spkr Upgrade,More to come.
    Mar 2006
    Its in the FAQ at the top of the X Type forum
    http://www.jaguarforum.co.uk/viewtopic.php?f=14&t=725
    Link on that page has pics to guide you
    BuckMR2
    Rear Entertainment , 2012 Nav
    DPF removed, EGRs deleted,
    kitchen sink...
    Jan 2010
    Thanks for that Prod Eng, had it out in a few minutes.
    BuckMR2.
    I had a look at FAQ first but the info on removing Sat/Nav/Radio assy had been taken out.
    I had purchased a DVD full manual with all this info on it but it doesn't work on my computer.
    Mar 2006
    Check under radio removal
    BuckMR2
    kitchen sink...
