Results 1 to 8 of 8
Thread: Prop Shaft Bearings
    Feb 2008
    Hampshire
    Prop Shaft Bearings
    For a while now I have been getting a whine from somewhere like the gearbox or diff etc. It is more pronounced after a run but is noticeable most of the time up to about 30mph. The advice from jag was to turn the radio up!
    Been in a specialist garage today and they have traced it to the centre prop shaft bearing. They are going to have a go at re-greasing it etc. but if that doesn't work jag have said that the bearing is not available separately and a complete prop shaft assembly will have to be bought - cost approx. £750
    It's a 2002 face lift model V6 Auto.
    Has anyone else had this problem and managed to fix it without buying a complete prop shaft?
    Many thanks
    Andy
    Andy C
    2002 3.0 SE Auto (Facelift model)
    Jan 2009
    Kent / London borders
    Re: Prop Shaft Bearings
    A bit of a distance, but if it saves a few quid !
    http://www.jwtransmissions.co.uk
    Nov 2009
    £20 each way by courier....
    2003 S Type Sport 3.0 Manual fitted with Servo Assisted Clutch designed and installed myself
    2000 XJR being restored by me
    Sep 2010
    Staffordshire
    Andy, excellent suggestion from Tyreman It's only in Kent. I see they offer balancing, could be worth asking them? about that. less vibrations the better.
    Hope all works out for you.
    Roger.
    Senior Member martin.rowe's Avatar
    Apr 2008
    Stoke-on-Trent
    presume its the centre bearing, you cant grease them, sealed unit, yes you should be able to replace it.
    Rally Drivers Do It Sideways
    2002 S Type R with LPG
    Master vehicle technician. IMI Professional Advanced Tuner.
    Please check out my Facebook page: Snows Garage Ltd.
    Feb 2008
    Hampshire
    Well, the bearing was re-greased on Friday and it seems to have been successful . Been on a good run today and no sign of any whine so am really pleased as it cost £105 which is less than a 10th of the cost of replacing the prop shaft. Long may the silence continue!
    Andy
    Andy C
    Jun 2008
    N.I
    Glad to hear it, Or not hear it as the case may be.
    smile they said, life could be worse! so i did and it was!!!!
    Jun 2010
    East finchley, Barnet, London
    Hey Andy C where did you end up fixing your car?
