Results 1 to 6 of 6
Thread: Why does my car hesitate when cruising at 50mph
    Feb 2011
    Hi,
    I wonder if anyone can help, I have a lwb 1994 Jaguar Sovereign that seems to reach 50 mph ok but when you cruise at that speed or upto say 65mph, the rev's seem to fluctuate even if you don't change the throttle setting and it seems to hesitate to.
    Has anyone come across this before or can anyone provide some direction? I wondered if it might be a throttle position sensor but thought I would see if there was another explanation.
    Mark
    Senior Member wilf's Avatar
    The naughty step
    Re: Why does my car hesitate when cruising at 50mph
    As a first place to go, I might suspect plugs or coils.
    XF gone due to intransigence of Jaguar marketing. New Rangie Sport on the drive!
    Feb 2011
    Hi Wilf,
    I am not very mechanically minded but would the plugs or coil only play up between say 50mph and 65-70mph and then be ok? The problem is not under accelertion either but rather when you maintain say 50-60mph.
    Mark
    The naughty step
    in a word or two - they might. But as I said, that is only one possible cause.
    Administrator 12RM's Avatar
    Oct 2005
    Scotland
    Could be the auto box.
    ex 2001 S Type 3.0 SE Auto
    ex 1997 X300 3.2 Sport Auto
    Jan 2010
    Isle of Wight
    had similar fault years ago on XJS. Fault was the potentiometer.
