Results 1 to 3 of 3
Thread: prop shaft bearing
    Nov 2011
    prop shaft bearing
    Could somebody describe the symptoms of a worn prop shaft bearing please, thanks
    Dec 2006
    South Yorkshire
    Re: prop shaft bearing
    Knock/clonk on taking up the drive from rest or when running slowly in traffic and alternately slowing/speeding up.
    Noise proportional to speed.
    There will be play in thre bearing if it is worn and should be detectable when car is stood by twisting and lifting.
    Yorkie
    2011 3.0D XF PL
    previous cars:
    2007 X Type S 2.2D with Jaguar body styling kit
    2004 S Type 2.7D.
    2000 S Type 3.0 SE
    Senior Member martin.rowe's Avatar
    Apr 2008
    Stoke-on-Trent
    Centre bearing will give similar noise as wheel bearing, rotational, increase with speed. Failed U/J's (prop joints) will give vibration, and knock when going on / off drive, U/J's easiest to check as per yorkie's post. You may have to remove prop to check centre bearing, it will be noisy when spun, also may get warm in use.
    Rally Drivers Do It Sideways
    2002 S Type R with LPG
    Master vehicle technician. IMI Professional Advanced Tuner.
    Please check out my Facebook page: Snows Garage Ltd.
