Hello and Welcome to Jaguar Froum Register
if this is your first visit, please click the register button to join the worlds #1 jaguar forum!
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: x
    Guest
    x
    xx
    Guest
    xx
    Guest
    xx
    Administrator 12RM's Avatar
    Oct 2005
    Scotland
    It will, just work at it.
    ex 2001 S Type 3.0 SE Auto
    ex 1997 X300 3.2 Sport Auto
    Guest
    xx
    Oct 2005
    Scotland
    Quote Originally Posted by rowanremote
    said with confidence. are these boot locks known to seize up?
    Yes, folk never use them till they find themselves in your situation or the battery goes flat.
    When I bought my X300 (sold but I pass it when I go to work) years ago the key would not work and even when loosened up it took a bit of force to open it. If you are going to ask me how many degrees of turn it takes to unlock, I cannot remember.
    Edit - you can also apply power to another point in the car from the battery you removed and pop the boot that way.
    Guest
    xx
    Guest
    I did wonder about that. how do you do this?
    Oct 2005
    Scotland
    I did not see this, I replied to your PM. Take care and make sure you get the polarity of your connections right.
    Senior Member smorris_12's Avatar
    Oct 2006
    Hampshire
    but the drivers door lock is so smooth and can't be used often either.
    If it's downward facing like the S-Type then the boot lock suffers worse as the aerodynamics through all the road muck & water up at the lock.
    Scott
    Where are we going and why am I in this handbasket?
Powered by vBulletin® Version 4.2.3
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
