Results 1 to 2 of 2
Thread: X Type air con not working
    Jun 2012
    Post X Type air con not working
    Hi just got my first X type jag & love it, I have never used a forum before so please bear with me. Its a 56 plate X type 2.2 diesel estate sport, and the problem is no air con. It has been re-gased, and there are no leaks, holding pressure fine and condenser o.k, checked the blend door also working correctly. Pump also kicking in as it should when the aircon button is pressed. When the air con is on the aluminium pipes at the rear near the fire wall do not get cold or clammy, so it appears nothing is getting through. I have been told it could be a valve not working correctly? any ideas are welcome. Please help! I have run out of ideas. Thanks Al
    Senior Member G4GVB's Avatar
    Dec 2011
    Spalding Lincs
    Compressor ? It was with mine, same symptoms.
    2006 S-Type 2.7L Auto Sport Diesel - Fully Loaded. . . . . Radio Amateur G4GVB since 1975 . . . . . www.qsl.net/g4gvb
Tags for this Thread
