Results 1 to 4 of 4
Thread: Jaguar s type - idle problem - racing & stalling
    Aug 2011
    Jaguar s type - idle problem - racing & stalling (FIXED)
    my 2000 3.0L Jag s type has developed a problem over the last week...
    it runs fine when cold but when hot (30 min journey) it races to between 1500-3000 rpm when slowing down at junctions but drops to tick over when at a stand still but after 2 or 3 mins it will stall ...
    it accelerates fine and pulls as it should.
    i cannot see any (or hear) air leaks in the inlet pipes - any ideas? air flow meter ? split engine breather pipe at the back of the engine, under the manifold?
    thanks
    mike
    Jul 2009
    Yorkshire
    Classic air leak symptoms.
    Read on here to save yourself money as fairly easy DIY fix.
    Aug 2011
    So the rubber elbow is for the vacuum? (rear on inlet manifold next to bulkhead) - it seems to idle correctly if it pull the pipe off and hold my finger over the pipe...
    can i replace the elbow without removing the inlet manifold..?
    thanks
    mike
    http://www.gusglikas.com/images/Auto...VacuumLeak.pdf
    inlet manifold off...
    Aug 2011
    repair done today.
    time taken about 4hrs all in with messing about.
    problems - vacuum pipes brittle and fuel pipe starting to crack and perish - will need replacing in the summer...
    mike.
    ive made a quick PDF on what i did.
    http://depositfiles.com/files/jdf58tlbl
    thanks
Tags for this Thread
