Results 1 to 10 of 18
Thread: X-Type 2.5 AWD whistling noise????
    Senior Member daz9tt's Avatar
    Dec 2010
    Northumberland
    Hi folks,
    In this last couple of days my car has developed a strange whistling noise..............
    Every now and then, I hear this whistling. It sounds like something from an old horror movie, like the wind howling by. Very strange and a real mystery.
    I've read on here before about a whine that can eminate from the 'transfer box'. I've heard that in the past and it's never caused any problems, but this is very different.
    Anyone got any ideas???
    Cheers.
    My Wife just asked me for a double entendre............ so I gave her one!!
    X-Type Saloon
    Black 2.2d Sport Premium
    Aug 2012
    burton on trent
    sounds like the centre shaft bearing
    mine does it
    quite a high pitched noise
    i'm led to believe its happens more often when the weather is cold
    Dec 2010
    Northumberland
    Thanks for that.
    Hmmm, could be something in that then.......... coincidence that it's just started this last 2 or 3 days since the weather has got really cold.
    X-Type Saloon
    Senior Member Aonsaithya's Avatar
    Jun 2012
    Finland
    Here as well, the last two days were -15 degrees centigrade and I got a bit of a whistle on motorway speeds, both when accelerating and when decelerating (engine brake). Not all the time, just occasionally. I've read up a few threads on similar issues, and typical suspects seem to be the centre shaft bearing and rear differential.
    Sold: Platinum 2001 X-Type, 2.5 V6 Manual SE, in Dove & Granite
    Mina Gallery exhaust, AEM DryFlow intake sans resonator, EBC RedStuff pads
    Drilled pedals & wooden steering wheel, rear tread plates, AUX-IN mod
    Senior Member Big cat little cat's Avatar
    Jan 2011
    North Midlands.
    Mine used to do this, but it's either cured itself or I just don't hear it anymore.
    Resonanting sound, only appeared at 60mph. Most likely the centre bearing. Not worried.
    Just when you think you can see a light at the end of the tunnel,
    you find that it's just someone with a torch bringing you some more work!
    X-type 3.0 Sport Premium Estate Auto.
    Link to retro fit cruise control for 2004-on AWD cars here. http://www.jaguarforum.co.uk/f26/ret...+control+retro
    Nov 2008
    Gosport, Hampshire
    I occasionally get the same too, common thing with the X-Type, centre shaft bearing whines, it's either put up with it, which is not threatening to the propshaft, or pay £600 for the joy of no noise from Jaguar.
    Jaguar XK Coupe 4.2 2006 (2007 MY) indigo blue.
    Mods: Power-fold door mirrors, ally weave dash trim, late model chrome stalks, XKR pedals, ACM kit, Speedpack Spoiler, XKR exhaust, late model seat and window switches, Alston Suede roof lining, Upper/Lower Mesh grilles, Redstuff pads all round. Aerial removed and re-located to spoiler.
    Resident Super Moderator.
    Dec 2010
    Northumberland
    So this centre shaft seems the most likely cause!! Thanks for the info......
    I'm wondering if this will mean a visit to the dealer in future?
    I've had the car 2 years now, and it's been used in much lower temperatures (the first winter I had it it was driving in -15 and heard nothing) so maybe this is something that gets steadily worse. Where I am has only been -1 / -2 this last few days. Strange it starts happening now.
    Guess I'll see if it cures itself when the winter breaks. If not, maybe hand in the pocket again???
    Thanks all.
    X-Type Saloon
    Member slocs's Avatar
    Jul 2011
    Sydney, Australia
    Mine also does this, but as the others have said it is somewhat intermittent (and it's doing it at the moment despite a couple of 38 degree days).
    This weekend I'll try the centre bearing grease fix and I'll report back.
    Rob
    X-Type 2.5SE ("Mick Jaguar")
    911 3.2 Carrera Cabrio ("Jose Carrera")
    Dec 2010
    Northumberland
    Just to continue......
    Found some guidance on another Jag forum for greasing the centre bearing to try cure this whistling noise problem. See link:
    GREASING Propshaft Center Support Bearing (FAQ) - Jaguar Forums - Jaguar Enthusiasts Forum
    Had my car in my Father-in-Laws workshop yesterday.
    Jacked up and removed the two bolts from the centre bearing holding bracket. We spun the bearing by hand and all felt very smooth. So no damage or wear noted then.
    Instead of trying it the way noted on this other forum, we just applied a load of spray on grease around both sides of the bearing.
    For the rest of the day, hey presto - no whistling noise.
    I guess maybe a case of waiting to see how long this bit of spray on grease lasts, but so far so good it seems.
    X-Type Saloon
    Senior Member daveh's Avatar
    Jul 2009
    Isle of Thanet
    This topic always crops up on the 4 wheel drive models when the temperature drops. I've had my 2.5 Estate for 4 years now and sometimes the whine is there and sometimes not in the winter. I've learned to live with it. It was worrying when I first heard it but there are so many threads on the website with various analysis. Come the spring, or warmer weather anyway and unless there is something seriously wrong, the noise will disappear.
