Results 1 to 4 of 4
Thread: Diesel injectors
    Senior Member beanmasteruk's Avatar
    Jun 2008
    Farnborough Hants
    Diesel injectors
    Anyone know good recon injectors or had any issues with them?
    May 2010
    I don't think there is much trouble with reconditioned injectors themselves, rather the coding of them after.
    Each injector has a calibration code and these codes need updating within the ECU.
    So you'll need someone with the correct equipment to do this, otherwise it can run like a bag of spanners.
    Someone {(forgive me I can't remember who) descrided them like guitar strings.
    Fit a new one and it will make a noise (run), but you need to tune it to get the correct note (run properly).
    There are plenty of good diesel specialists that will supply renditioned injectors.
    I've never used any of these, but I've heard their reputation is good.
    Diesel Fuel Injectors | Diesel Engine Problems - United Diesel, Shropshire
    Diesel Bob Tuning - Home
    Jaguar X-Type S Common Rail Diesel Injector
    A word of note, there are two different injectors fitted over the production run.
    501Z and 504Z.
    Out of curiosity, why do you need injectors?
    Senior Member Andy5112405's Avatar
    Redditch
    I'm pleased to see that the price of them has started to slip. New injectors can now be had for as little as £75 but more generally at about £150.
    By the time you add on the cost of the special tools required and the guarantee and ultra-clean working requirements, it's probably a job best left to the specialists.
    2013 XF Sportbrake 3.0TD-V6 Premium Luxury. All the toys that were available.
    Previous Jag's. 2001 2.5V6 X type SE Saloon & 2008 2.2TDi X type Sovereign Estate.
    Jun 2008
    Farnborough Hants
    Mine have gone off to mondeospares.co.uk. After a day of ringing around and getting quotes and info, these guys seem both knowledgeable and inexpensive, together with a good turn around. Some have quoted £180 for refurbed injectors, even though my local jaguar dealer quotes £168 for new ones! Have found them for as little as £100 but am wary. Average price is about £120-140 plus VAT. Mondeo spares in stoke on Trent quote £99 to recondition and they are Delphi credited. They also offer a clean and inspect for £21 each. (all there prices include VAT too) so sent mine off today. I'll get them tested and if all four need a rebuild it's only £480, but if one or two are tested ok I save a few quid. I've had hot start issues, lumpy running, smoking etc etc. have done reflash,EGR and reprogramming them, all to no avail. I'll report back when injectors are returned on Thursday, as I can fit them and programme them myself. Fingers crossed
