Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: How to use the JLR SDD software?
    Senior Member Fitzy's Avatar
    Feb 2012
    Crawley, West Sussex
    As the title says.
    How do you use the JLR SDD software?
    My SDD V131 is all up and running with my mongoose cable and it connects to my X350 XJ8 no problem.
    But how do I get in to the section to configure my car, like dipping mirrors, ride height and other configurations etc?
    In case I ever need it, how do I programme a new key (if its possible that is)?
    Don't want to just go in blind not knowing what I'm doing and screw the car up.
    Any help greatly appreciated.
    Dave
    Dave
    2003.50MY Facelift Midnight Black XJ8 3.5 V8, Electrochromic Rear View Mirror & Electrochromic Folding Wing Mirrors, Heated Dove Grey Leather Memory Seats with 16 Way Adjustment, ARTS Active Headrests, Factory Sat Nav, Factory Bi-Xenons, CATS Air Suspension. Bluetooth & Voice control now retrofitted and working. Currently about to start the rear entertainment retrofit.
    Member Dell's Avatar
    Feb 2013
    Warwickshire
    Hi dave have a look at this forum you may find what you want here Index page : OBD-Codes.com
    Also this site to find what code is referring to http://www.dtcsearch.com/
    Old man but still learning
    ​2003 X Type 2.5 V6 Zircon blue manual cream leather
    Feb 2012
    Thanks Dell
    But I couldn't find anything on that site explaining how to use and navigate the JLR SDD software.
    Dave
    Dave
    Feb 2013
    Warwickshire
    I have found this have a look have uploaded it to my dropbox https://www.dropbox.com/home/New%20folder
    Feb 2012
    Dropbox keeps asking me for a username and password.
    I had another go this afternoon and dug a bit deeper but every time I tried to run a configuration like add/remove accessories I keep getting a "tabman error = error" flash up and it won't go any further and freezes.
    i had problems when installing the spa_dvd131_v6 file and got some "cannot load certain file errors" and had to click the ignore button to continue the install (got new discs with v130 & v131 coming from the supplier). Could this be causing the tabman errors?
    When I try to uninstall SDD not all of it gets uninstalled as when I try to reinstall it asks me if I want to modify or uninstall certain files.
    I have it installed on my Dell inspiron 10 netbook with an atom processor, could this low spec cause the errors?
    Dave
    Dave
    OriginalCaruso
    Guest
    Quote Originally Posted by Dell View Post
    The link points to a folder in your Dropbox home directory which only you can see, any chance you would PM Fitzy and I external link please?
    Feb 2013
    Warwickshire
    Fitzy and Originalcaruso i have PM you both sorry i am new to this as my signature said old man but still learning i can not claim the PDFs in my drop box as i found them on other forum but can't remember the forum.
    Dell
    OriginalCaruso
    Guest
    Dell you are a star! Don't stop learning!
    Senior Member Timjag's Avatar
    Aug 2012
    Stafford
    Just bought and recieved the Mongoose cable and software. Intalled the software with no problems, Green light flashes away
    when connected to my acer laptop so as per the mongoose guide.
    I cant see the drew technologies software, I have found 3 files Mongoose quick start guide, Mongoose user manual and Mongoose JLR.
    My question is, will I see the program once I connect to the ODB2 port of the Jaguar or is there another way of viewing the program without
    making the connection to the ODB2 socket
    X Type 2.2 Executive
    Sep 2013
    Dell
    Can you also pm me the pdf?
    Thank you in advance
