Results 1 to 6 of 6
Thread: Do not install KB2859537-KB2868623 Win7
    Senior Member Shukan's Avatar
    Mar 2013
    Essex
    Do not install from windows update the two above security updates, search the two KB terms ,causing BSOD or constant reboots in trying to install , once completed programs from third party apps will not work , you will need to reformat the whole op system unless you have system restore active even in some cases this does not work as the Kernel of Windows is badly effected.
    Black ST-R-2006_Polished Caldoofy Elbow with wide open throttle mod best 1/4 mile 108.00 mph
    Senior Member djdex's Avatar
    Oct 2007
    Derbyshire,UK
    I've got both of those updates Shukan on three Win 7 machines with no problems, is it related to having some other software installed as well?
    Nov 2008
    Hampshire
    Sounds like they didn't install properly, I got one machine with the mentioned updates running fine .
    You tried putting in your windows DVD and try to repair the boot sector? In future partition your drive with only windows on one part and your files on the other half. Or image your drive for back up every so often.
    Jaguar XK Coupe 4.2 2007 indigo blue.
    Mods: Power-fold door mirrors, ally weave dash trim, late model chrome stalks, XKR pedals, ACM kit, Speedpack Spoiler, XKR exhaust, 5.0 XKR diffuser, late model seat and window switches, Alston Suede roof lining, Upper/Lower Mesh grilles, Redstuff pads all round. Aerial removed and re-located to spoiler.
    Resident Super Moderator.
    Mar 2013
    Essex
    Some machines are not effected according to a google search , Microsoft acknowledges the fact that there is a problem this was Tuesdays August update and have now pulled the offending updates , google the offending security updates and this will explain the problems, All my Windows machines do not have this update just in case, my friend in Germany where i have just come from had the updates and it crippled three of his machines so i have seen this happen , a constant cycle of trying to implement the patches then reverting to undoing windows update , then you find the machine is crippled and third party programs do not work.
    If you have a SSD fitted you should have Windows restore disabled so this will not save you ,
    Mar 2013
    Essex
    Quote Originally Posted by djdex View Post
    Have read that kaspersky anti virus may be a problem as this works low level at Kernel , saying this the other machine my friend had did not have this installed but was effected.
    Senior Member iwvc's Avatar
    Dec 2008
    London
    Neither of these has featured in the list of updates (or failed updates!) following this weeks re installation of Win 7 64 so I can oly assume MS hve pulled it because of reported problems?
    Ian C
    2005 2.0D SE Estate
