Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Cd autochanger retrofit
    Jan 2017
    Hi guys, going to retrofit a cd autochanger. Just wanted to know what I'll need. I've a 2006 one with the standard radio/cd player
    Senior Member Eyeballroy's Avatar
    Apr 2014
    Kent
    I think all you will need is the multi changer and additional optic leads, the plugs should be in the boot taped away behind the left panel. The optic leads have to be connected in a certain daisy chain order with your existing modules, i.e voice sat nav etc.
    Jaguar XFS 3.0 380bhp all the toys
    Previous Jags
    XE 2.0 Portfolio 2015/16 in Celestial Black and fully loaded
    XF Sportbrake 2.2 Portfolio 2014/15
    XF Premium Luxury 3.0 2013
    XF Premium Luxury 2.7 2008
    S Type 2.7 Diesel Sport 2005
    X Type 2.5 V6 AWD Estate 2004
    S Type 3.0 SE V6 petrol 1999
    also have Yamaha FJR1300
    Apr 2015
    Hertfordshire
    Can be luck of the draw to find it prewired. Earlier cars were mostly but then not all and if the car doesn't have premium sound, nav, phone or voice and it's an 06 then it might not be. It probably won't have the bracket for mounting the changer either.
    You'll need to check for the wiring as eyeballroy says. You might be lucky
    Let us know how you get on and what you find.
    Cheers ... Jon
    2003 S Type V8 SE
    Retrofits:- Voice, premium amp, ACM, bluetooth, OEM park sensors, auto wipers, STR rear lights, rear blind, OEM spoiler, XF stalks
    Upgrades:- Android hack, reverse camera Autofold mirrors, Audiocontrol LC8i, JL Audio XD7005v2 amp, JL Audio C3-650 front, JBL coax rear, JL Audio 6W3v3-4 (x2) subs, Alpine Ezi-DAB, LED interior, mesh grills, Adamesh exhaust
    Maintenance:- Recon propshaft, new discs, new w/pump, new belts, new EBP, gearbox refurb
    To do:-
    Jan 2017
    Cheers guys, will do
    Jan 2017
    Hi guys, I don't seem to have any prewiring
    Apr 2015
    Hertfordshire
    Quote Originally Posted by Colummccormick View Post
    That's a pain. Have you looked everywhere carefully? They can be tucked away. I take it you don't have the mounting cage there either?
    Cheers .... Jon
    Jan 2017
    I've nothing Jon, only dust, dead spiders and some rust
    Jun 2013
    Why not get a Chinese SatNav/Radio/Bluetooth/DVD/SD Card/USB 2-DIN unit instead? £140 squid! Done and up to date maps too.
    Better ones with rear-view camera for a bit more.
    Much better solution?
    Apr 2015
    Hertfordshire
    Exactly what I was going to suggest Jim in these circumstances. Really depends what the OP wants in the end and how much he wants to spend. He has nothing there so the world is his lobster
    2003 S Type V8 SE
    To do:-
    Senior Member the fussy one's Avatar
    May 2012
    Bedford
    My stepson fitted a Chineese unit into his BMW. I was impressed with its function and even its looks once fitted. Having said that- would i fit one in my S type? Thats a no-no. But each to their own.
