Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 1995 XJS 4.0 Liter Convertible
    Mar 2018
    Tucson, AZ
    Rocky's 1995 XJS 4.0 Liter Convertible
    Thought I'd introduce my car, and myself.
    We are from Southern Arizona (Tucson), USA. Just got my car on a lark (it fell into my lap), and I thought my wife would enjoy cruising around in it.
    Like any 1995 car, it's got lots of minor things that need attention, but overall, it's got a solid body, good interior, brand new top, and is a good runner. I am confident it will make a good car for us.
    Rocky
ID:	26738Click image for larger version.
ID:	26739Click image for larger version.
ID:	26740Click image for larger version.
    Mar 2016
    Salisbury Wiltshire
    Nice collection Rocky. Welcome to the site.
    GM
    Mar 2018
    Tucson, AZ
    Thank you sir! It's a good one!
    Mar 2018
    Tucson, AZ
    Alternative Parts (Air Filter Canister Isolators) - US Only?
    (Maybe not for purists?)
    I decided to do a bit of a tune up on the Jag, and noted that the air filter canister isolators (they hold the canister to the fender) had both sheared off.
    I bought a set of:
    P/N 43967 or UP03483 Rubber Vibration Isolators off Ebay
    (Male - Male, 5/16"-18 threads)
    I removed the existing isolators, and with a suitable tap, I rethreaded the two captive nuts. This allowed me to easily mount the two new isolators.
    A few minutes cleaning up the airbox, and replacing the element solved this minor problem.
    Regards -
    Rocky
    PS> I still have an issue with the isolator on the rear of the plenum assembly - it has a 90* bend in it. That one sheared off as well. But I am 200% better than I was before, structurally....
Name:	IMG_8141 (Small).JPG
ID:	26775Click image for larger version.
Name:	IMG_8142 (Small).JPG
ID:	26776Click image for larger version.
Name:	IMG_8143 (Small).JPG
ID:	26777Click image for larger version.
Name:	IMG_8144 (Small).JPG
    Mar 2016
    Salisbury Wiltshire
    Hi Rocky - you remind me that I must do mine soon. The rear one at the intake elbow in your third photo is a different part number but available from SNG Barratt if you want to go "purist"!
    GM
    Mar 2018
    Tucson, AZ
    Hey Grubster!
    (That is a pleasant, "chumly" greeting! I am greeting you, because you seem to be the only one responding to this topic!)
    I took a look at the rear isolation mount, and it can use the same isolators as the ones up front. There is an "L" shaped (actually a "7" shaped) metal bracket that mounts to the endo of the "standard" isolator.
    I inserted a picture of the finished mount.
    Also swapped out the front shocks - it turns out that really all I needed was the upper bushings, but.....
    Note in the lower picture, I didn't really like how the shock was located on the thinner bushing carriers (that came with the shocks), so I made a spacer from an expanded lock washers that will positively locate the shock rod in the center of the mounting hole.
    Regards -
    Rocky
Name:	IMG_8145 (Large).JPG
ID:	26792Click image for larger version.
Name:	IMG_8147 (Large).JPG
    Attached Thumbnails Attached Thumbnails IMG_8148 (Large).JPG   IMG_8150 (Large).JPG
    Mar 2018
    Tucson, AZ
    Interested in learning about how the handbrake operates?
    Follow my journey in this thread!
    http://www.jaguarforum.com/showthread.php?t=107651
    See if I am eventually successful!
    Rocky
    Senior Member Henry_B's Avatar
    Oct 2016
    Hereford,uk
    Love your collection!!
    Not jealous at all
    XJS is looking great!! apart from the steering wheel being on the wrong side
    Radiance Red Jaguar S type 3.0 - internally incontinent
    Monte Carlo Blue Range Rover 4.6 Vogue - Retired.
  9. Thanks Rocky_USA thanked for this post
    Likes Rocky_USA liked this post
  10. #9
    Mar 2018
    Tucson, AZ
    Another question. I have a light beige (cream) interior, and my driver's seat is seeing the ravages of the Arizona summers. I'd like to treat it with a leather preserver.
    Can I use Neatsfoot oil on the seat?
    I guess I am worried it will change the color, or not come out evenly.
    Recommendations? I'll try and get some pictures of my interior and seats in the next couple of days.
    Thanks -
    Rocky
  11. #10
    Mar 2016
    Salisbury Wiltshire
    Hi Rocky
    I used products from Furniture Clinic for mine - with great results. Link below.
    https://www.furnitureclinic.co.uk/Neatsfoot_Oil
    Good luck.
    GM
  12. Thanks Rocky_USA thanked for this post
