Results 1 to 10 of 17
Thread: Weird noise?!
    Senior Member Henry_B's Avatar
    Oct 2016
    Hereford,uk
    Weird noise?!
    After running her for a while a rhythmic tapping noise can be heard, i hunted around her for a good half hour with no success..
    However after unintentionally resting my hand on the expansion tank i found it..
    Not only does it sound like a heartbeat but i can feel the tapping.
    I've pulled the cap off and there is no obvious signs of oil locks,.
    I've tried bleeding it and no air was in the system.
    Heater works fine etc etc
    Weird issue, it feels exactly like a heartbeat!!!!
    Radiance Red Jaguar S type 3.0 - internally incontinent
    Monte Carlo Blue Range Rover 4.6 Vogue - Retired.
    Senior Member payno's Avatar
    birmingham
    Try putting your hand on the water pump hose to see if it feels stronger there
    S TYPE R 2003
    BMW M3 EVOLUTION 1998
    Oct 2016
    Hereford,uk
    Quote Originally Posted by payno View Post
    The throbbing feeling is only in the expansion tank all the hoses are good, no feeling into them
    The throbbing also increases with engine RPM!
    weird.
    birmingham
    That still makes me think water pump I suspect you may have to wait for it to get worse before the problem becomes apparent
    S TYPE R 2003
  5. Thanks Henry_B thanked for this post
    Likes Henry_B liked this post
  6. #5
    Senior Member S-Type Owner's Avatar
    Jan 2018
    San Francisco Bay Area
    A mechanic's stethoscope would help you track down the noise. They are not expensive. My only caution is to be careful using one near moving parts, i.e. serpentine belt, pulleys and tensioners.
    2003 S-Type 3.0, Zircon with the "Premium Package"...
  7. #6
    Jun 2013
    Even better is a 1960s 2-foot wooden-handled screwdriver held against your ear.
    But you have to be qualified to use one.
  8. Likes S-Type Owner, rchiv liked this post
  9. #7
    Oct 2016
    Hereford,uk
    Ok the car is not pressurising
    And it smokes out the exhaust like a kettle even when hot so i'm suspecting Head Gasket.
    Fook me.
  10. #8
    birmingham
    Can you do a compression test H ?
    S TYPE R 2003
  11. #9
    Oct 2016
    Hereford,uk
    Just hitting a dead end.. tbh it looks like HG, but all the cars are producing steam so 50/50 at this point.
    I'll see if i can acquire a compression tester!
    It can be driven for left idling and there is absolutely no pressure in the cooling system..
    You can open the lid and there isn't so much as a hiss..
    But the weird thing is, she doesn't use coolant..
    Hmm.
  12. #10
    Jul 2009
    Yorkshire
    Quote Originally Posted by Henry_B View Post
    So it may not be a disaster.
