Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Replacing rear wheel bearings - what tools for different bolt heads
    Aug 2016
    Cambridgeshire UK.
    Hi gang, trust you are well.
    I have ordered some good branded replacement rear wheel bearings
    Also in the post is a long shaft Torx 40 as I'm expecting to find the old bearing assemblies attached by T40 bolts.
    I noticed that the bolts pictured with the replacements are not female T40 but male T40. It's not so clear in the image.
    It doesn't look like a socket could get in there?
    Has anyone had to fit these bolts, and what tools did the trick?
    Thanks for any pointers.
    What are these nasty BMW looking fixings eh?
    2006 Black Jaguar X400 | 6 Speed Manual Transaxle - MMT6 | Series 60 | 2.2L Duratorq 16V TC (150PS) - Puma | 4 Door Saloon
    Senior Member x_type_lpg's Avatar
    Sep 2012
    Frinton on Sea
    factory fit is normally female bolts and aftermarket male bolts, if you look at the holes on the hub one is larger than the rest and allows a 3/8" extension bar to pass through and engage the t drive.
    spray lots or oil on the threads from the back, and hope the abs sensor comes out easy and dont get stuck.
    Aug 2016
    Cambridgeshire UK.
    Quote Originally Posted by x_type_lpg View Post
    factory fit is normally female bolts and aftermarket male bolts, if you look at the holes on the hub one is larger than the rest and allows a 1/4" extension bar to pass through and engage the t drive.
    Thank you. That is reasuring. Knowing an extension will fit throught one of the holes will be the solution. Thanks. I will take your advice.
    Apr 2017
    Milton Keynes
    The new bolts are an E something , cannot remember the number as I normally just use socket caps.
    Give it all a good drowning in plus gas all around the round seating area of the centre hub as well as fasteners.
    As per previous message , the hole in the hub is for a short extension to fit through.
    2009 X358 LWB 2.7 Tdvi , Liquid Silver , 125k+ and going strong ......
  5. Thanks Jag-Black thanked for this post
  6. #5
    Senior Member rchiv's Avatar
    Feb 2013
    Orpington, Kent
    I remember when i did mine that I had to file the larger hole a bit to allow the Halfords Professional 3/8" T socket to fit through. It was not required on the new one as the Female E socket is smaller in diameter and fitted without any problem.
    2006 X Type 2.2d SE Manual Estate. Zurcon Blue Champagne/Mocca, F/R Parking sensors, ,Auto Lights, Auto Wipers, Headlight Washers, Sat Nav 2012 update, 17 in Wheels, 119K Mods:- Electric Autofold Mirrors on Locking
  7. Thanks Jag-Black thanked for this post
  8. #6
    Senior Member willowbob's Avatar
    Nov 2012
    Swansea, SW Wales
    Quote Originally Posted by Jag-Black View Post
    I did mine not so long ago and, from memory, I think they are T50 Torx heads? I used a long extension T50 Torx socket, loads of penetrating fluid on the night before, heated them up with a blowlamp, then half a turn forward, more penetrating fluid, quarter turn back and so forth. If they 'round', (one of mine did) I used a set of rounded bolt removal socket tools on them, which did the trick. Try as hard as you can NOT to snap them in there! Good luck.
    Jaguar 2.0D SE 2008 Estate, 107K, Glacier Blue, Heated Leather, Cruise, Sat Nav and praise the lord good sills and no DPF
    Life lessons I have learnt - We are where we are.......It is what it is.
  9. Thanks Jag-Black thanked for this post
  10. #7
    Aug 2016
    Cambridgeshire UK.
    Thank everyone for the feedback. I'm in two minds as to if I'm gonna do it myself. I'm not well practiced at these things so it could turn into a nightmare.
    Bearings arrive today.
  11. #8
    Aug 2016
    Cambridgeshire UK.
    I went yellow belly and booked it in to have the bearings fitted.
    They quoted me for a couple of hours work, and if it's quicker I'll save a bit, which i thought was probably realistic since they've been dragging through the wet for 180K miles, and if I thought it was going to be easy, then I would have done it myself.
    Can't wait.
  12. #9
    Apr 2017
    Milton Keynes
    If they have ever been done before and greased up properly , a couple of hours will be plenty.
    Can be a bit of a pig otherwise , still nothing major for a good repair shop to carry out though.
  13. Likes Jag-Black liked this post
  14. #10
    Senior Member BenedictWhite's Avatar
    Oct 2013
    Mid Sussex
    Here is a video of me doing mine when it went completely pair shaped. If you run into issues this video shows ways to get around them:
    Kind regards
    Benedict White
    Jaguar X Type Sport Estate 2.0D, 2004 (127,000 miles) with most of the toys!
    To edit your signature, go to the top right of the forum and click on settings. On the left side you will see 3 panels, The 3rd is "My Settings". Under my settings you will see edit signature.
    How to re program tailgate glass see here.
  15. Thanks Jag-Black thanked for this post
