Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Oil brand for XJ 5.0 Supersport
    Member markva44's Avatar
    Nov 2018
    Gloucester
    I'm getting the oil service done and I was wondering what oil brand is best. I know its 5/20 but I was wonderingwhat's the best for these motors.
    I've had a look and this seems good.
    AE 5W20 A1 Multigrade - Castrol Edge Professional
    co-engineered in partnership with Jaguar Land Rover for the latest generation engines
    • Castrol EDGE Professional A1 5W-20 is suitable for use in vehicles that require a 5W-20 lubricant that Meets;
      Ford WSS-M2C925-A
    • Ford WSS-M2C925-B
    • ACEA A1/B1,
    • API SL, ILSAC GF-3 or earlier specification
    Jaguar XJ Supersport 5.0 Supercharged 510 bhp. Polaris white. Carbon fibre trim, loaded
    May 2017
    Brackley, UK
    Anything that meets all the specs.
    i personally use GM oils because it’s dirt cheap on trade club, but that’s in my deseasal that is a different spec to the 5l SC lump
    2010 XJ Portfolio running on lorry fuel. I know, Jag Diesel is just wrong!
    Nov 2018
    Gloucester
    very different
    May 2017
    Brackley, UK
    Quote Originally Posted by markva44 View Post
    very different
    Eh?
    The SC Petrol oil is different to the Diesel oil? Yup, I know...
    The GM TC oil is different to other oils? Nah.
    The Castrol oil is different to everything else? Probably not.
    Senior Member jasz1156's Avatar
    Apr 2014
    New zealand
    So the manual recommends SAE5W-20 engine oil meeting WSS M2C925-A only for the V8 motor. I used Castrol’s matching spec with my atmo v8 with no problems.
    The diesel oil is different being SAE 5W-30 spec WSS -M2C934-B only if it uses a particulate filter. IMHO the type of oil is far more important than extra changes between recommended intervals.I have also used fully synthetics for decades and swear by them provided they meet the specs.
    the PSA diesel is a different animal to the Ford Mustang motor and I would look at Fords recommendations if in doubt.
    I’m not sure what Boys getting at but the issue is the oil spec not the brand.
    White XJL portfolio 3 litre s/c ecu to S MY2015
    Nov 2018
    Gloucester
    A friend of mine who is an indy and has been working on Jags for 35 years said the reason the tensioner can fail is the wrong oil grade and prolonged servicing.
  7. Likes Jimbov8 liked this post
  8. #7
    May 2017
    Brackley, UK
    Quote Originally Posted by jasz1156 View Post
    All EU soot chuckers will be DPF, not sure about rest of the world.
    I highlight this, because many of the UK online oil sellers recommend an inferior, DPF damaging oil when you pop in the reg.
    My clarification was I didn't understand markva44's comment of "very different". But, I concur with you, its the spec that matters.
  9. #8
    May 2017
    Brackley, UK
    You should always match the spec (not just the viscosity spec, but the full spec) no matter what, unless you really know what you are doing. The servicing intervals JLR state are suicidal for engine protection, they are ridiculously long for marketing purposes.
    Not ever checked if the 5l V8 is belt of chain. If it is belt, the oil servicing will not impact the belt tensioners at all.
  10. #9
    Nov 2018
    Gloucester
    its a chain
  11. #10
    May 2017
    Brackley, UK
    its a chain
    In which case completely ignore JLR's daft service interval, and change the oil regularly
  12. Likes #steve liked this post
