Results 1 to 10 of 10
Thread: Too cool for cool?
    Jul 2017
    Berkshire
    Too cool for cool?
    Was testing my Climate Control the other day up and down the temp range as i do from time to time since the problems i've had in the past.
    Outside temp was showing 8 C so i wound the CC down to low but got nothing more than a comfortable temperature ...no ice cold.
    Is there an outside cut off temperature below which the CC won't cool does anybody know? i seem to remember reading this somewhere on a post but could be wrong.
    If not its another chapter in the ongoing CC problems I've had for over 2 years.
    Jaguar XFR 2011
    Senior Member Poundy's Avatar
    Oct 2013
    Alvechurch
    Isn't the lowest setting around 16? if you had it on auto at 8 outside it would warm the car up to 16 instead of adding more cooling.
    64 Plate RSport 3.0D All Black, Ceramic coated, self healing front car wrap, 19" alloys
    Nov 2007
    There will be a low temp cut out for the air con to prevent the evaporator from freezing solid and blocking with ice.
    Senior Member Phil F's Avatar
    Apr 2017
    kent
    AC should switch off when outside temp gets to 3 or 4 deg C
    Jul 2017
    Berkshire
    Quote Originally Posted by Phil F View Post
    Hmmm...outside temp showing 14C today.
    Switched up and down the range, heat works fine.
    Compressor works fine can switch on and off from computer and hear rev change.
    Setting the temp down to 16 or Lo...fan speeds up but no icy cool ...just a normal temp roughly the same as outside i assume.
    CC would appear to work though, i set it to about 21 on auto and I'm getting nice clear windows and no misting up.
    but this seems wrong i would expect to be able to switch the CC down to icy cold at 14C outside ...I haven't checked pressures since summer when it was working fine but i can assume it's back to a leak somewhere that appears impossible to detect despite being looked at by 3 different garages and approximately 10 refill/dye - diagnostic sessions.
    Jaguar XFR 2011
    Senior Member Neilr's Avatar
    Jan 2007
    Germany
    You could warm up the interior of the car with a fan heater and then test.
    Nov 2007
    If it demists quick the air con is probably working.
    Jul 2017
    Berkshire
    Yeah it appears to be working just not chilling
    Jaguar XFR 2011
    Apr 2017
    kent
    Quote Originally Posted by VNC View Post
    My air con still gets cold if I turn it down so suspect yours may be a bit low on gas or other fault . When gas gets too low it will not switch on and clutch will not engage on compressor
    Jul 2017
    Berkshire
    It could be low on gas although I've had the same problem some time back and pressures were fine. I suspected it was the DPSV (a common problem) so had that replaced.
    Note the compressor works and switches in and off via the control panel, There is no clutch in the compressor It's of the constant displacement type.
    Jaguar XFR 2011
