Results 1 to 7 of 7
Thread: Seven Of The Strangest New Engines In The Industry
    Apr 2011
    https://www.enginelabs.com/news/vide...n-the-industry
    The Achates diesel engine is essentially a Boxer engine turned inside-out. The two-stroke, two-piston-per-cylinder design is unique with intake and exhaust ports on opposite ends of the cylinders, “controlled” by different pistons
    XF SV8 A - USB 2 - B&W 440W - Parking Aid Pack with Rear Camera - CAT Suspension - TPMS - 20" Volans - Headlamp Powerwash - Rain Sensitive Wipers - Xenon Headlights - Heated Windscreen - Intrusion Sensing - Navigation with DRG and TIS - ACC - Forward Alert - Memory Function - Blind Spot Monitor - Bluetooth Connectivity - Automatic Headlamp Leveling - JaguarVoice
    Jan 2016
    Rhyl, North Wales
    Santer,
    I'm not sure but I believe that this type of engine has been around for a while as fitted to the Chieftan tank.
    It was a horizontally opposed two stroke multi fuel engine.
    2007 Slate Grey 4.2 XK-R Convertible
    Jagwrangler one touch roof and rear windows mod. Rear spoiler antenna and boot lid amplifier upgrade. Fuse 19 switch installed discretely below dash/steering wheel. Red stuff brake pads. Replacement white "R" caliper decals.
    Apr 2011
    Only ever had a water tank
    Senior Member Neilr's Avatar
    Jan 2007
    Germany
    I was reading about the new Mazda Skyactiv X engine the other day. Petrol engine that runs compression ignition (without a spark or with just a control spark) under certain conditions. Will debut in the 2019 Mazda3, I believe.
    Mar 2018
    Edinburgh
    The Achates diesel looks like an update on the Commer TS3 'knocker'. I can remember them in the 1960's and thought they sounded great.
    Rhyl46 - think you're right about the Chieftain tank. I think that engine was also a two stroke opposed piston design - although it was a six cylinder layout. It also sounded pretty good too from what I can remember,
    2014 XF 3.0D Portfolio / 2006 Kia Picanto 1.1LX
    Senior Member t0m4ever's Avatar
    Mar 2014
    Bucks
    They should bring back and modernise the Deltic engine Imagine having a T9 instead of a V8 under the bonnet.
    2005 Jaguar S-Type R in Ebony Black
    Feb 2016
    OSWESTRY, Shropshire
    Hello Santer,
    Commer had this configuration engine in the 1960s, supercharged two stroke, they sounded wonderful. Also the Deltic railway engines ah the same opposed piston but in a triangle formation viewed end on, i.e. three crankshafts.
    Alec
    2004 2.5 X Type Estate, MK 2 3.8 (Long term restoration), 2.5 P.I. Triumph saloon, 564 Hymer motorhome.
