Results 1 to 10 of 17
Thread: Michelin Pilot Sports 4S
    Apr 2011
    Looking for these and there are two types XL and XL MFS (MaxFlange Shield). The MFS is better wet rated and fuel rated but is around £11 less??
    https://www.tyreleader.co.uk/car-tyr...0/?m[4]=on
    XF SV8 A - USB 2 - B&W 440W - Parking Aid Pack with Rear Camera - CAT Suspension - TPMS - 20" Volans - Headlamp Powerwash - Rain Sensitive Wipers - Xenon Headlights - Heated Windscreen - Intrusion Sensing - Navigation with DRG and TIS - ACC - Forward Alert - Memory Function - Blind Spot Monitor - Bluetooth Connectivity - Automatic Headlamp Leveling - JaguarVoice
    Senior Member Neilr's Avatar
    Jan 2007
    Germany
    Looks like the more expensive one is the BMW spec one; the other the standard one.
    Apr 2011
    Odd that the standard one has better performance rating
    Senior Member jberks's Avatar
    Leeds
    Quote Originally Posted by santer View Post
    And we're often told there's no difference between OEM and Standard model tyres. It's all just a quagmire.
    2012 XF 3.0D S Premium Luxury
    Jan 2007
    Germany
    Seems to be often the case that to get a particular characteristic, other compromises are made. The generic version that tries to get the best balance they can across the board is often the best choice. One of the bigger car mags out here tested a few of the specific versions of a test-winning tyre against the standard one on the cars they were supposed to match and found that the tuned tyre was worse than the standard one. For most of us, under normal circumstances, there is probably so little difference, it makes no difference.
    Actually, when you compare tests, there is so little difference between the top tyres, it is hard to buy a bad one. Comparing and old, worn, hardened tyre with a new one is certainly going to favour the new one except maybe when it is bone dry and warm. All tyres will have a slightly different set of characteristics. We probably focus on the one we think is weak on our current tyres and strangely find that the new one is so much better, whether that be traction or steering response, etc.
    Most of us don't have the test track, measuring equipment or the consistency in at-the-limit driving ability to really say if one tyre is really all-round better than another, nor do we even have two sets of new tyres to compare. So relying on measured test results that suggest a tyre is consistently a good performer are our only comparatively reliable sources of information. The Michelin seems to be such a tyre, but it has been beaten by other tyres, also suggesting that the difference overall is rather small.
  6. Likes jberks liked this post
  7. #6
    Apr 2011
    Black circles say 285/35/20
    Tyre leader says 285/30/20
    Tyre leader is better price and they do have both sizes, front are 255/35/20
    Which ones to get please?
  8. #7
    Leeds
    This is true. In reality when you look at reviews, the difference between the mid range brands and top brands like Michelin are actually relatively small and for your average driver, inperceptible. Often the cheaper brands are actually better in some areas though of course not overall.
  9. #8
    Jan 2007
    Germany
    These cars with the staggered 20" wheels have: Front - 255/35/20 Rear - 285/30/20
  10. #9
    Apr 2011
    Rang black circles and they confirmed rears are 285/35/20 for the registration so ordered those
    Will the extra 5mm be an issue?
  11. #10
    Leeds
    Yes in a word - not much but the tyre sidewall will be taller than spec. May look a little odd and will have a tiny effect on the speedo. Either way, better to keep to spec.
    I was chasing tyres a couple of weeks ago and actually found Costco dramatically cheaper than anyone else for Goodyear. The also stock Michelin if you have a card.
