Results 1 to 3 of 3
Thread: New stereo, little help needed.
    Jun 2018
    Midlands
    I'm looking at fitting an aftermarket stereo, it says it does steering wheel control, but has this line "Only support resistance based analog signal input steering wheel" Will this work?
    It would be fitted with one of these kits. https://www.ebay.co.uk/itm/Double-Di...e/271083775020
    Daily: Since 2018... 2004 Jaguar X-Type 2.0D SE Estate in Jaguar Racing Green.
    Daily & Fun 2005 to 2018... 1994 Toyota Supra GZ Aerotop in Pearl Red (driven like GTA) (more reliable than the SAS).
    Senior Member Winco's Avatar
    Jan 2012
    Poole, Dorset
    When I fitted my double din stereo, I used something very similar from Bass Junkies.
    https://www.ebay.co.uk/itm/DFPK-14-0...:rk:4:razz:f:0
    The box in the loom works with the steering wheel switches and the stereo had a programming feature for the steering wheel switches. You select one of the multitude of operations and then operate the steering wheel switch you want to work with that operation. Works great.
    2007/57 X-Type 2.2D Estate Sovereign that is an SE with extras.
    Shadow Grey, Piano Black, Nav, Sunroof, front parking sensors, remote folding mirrors
    LED headlights, LED fogs as drl. Decat, Steinbauer, 21mm wheel nuts, Android Double DIN incl DAB & reverse cam.
    2009 Jeep Grand Cherokee 3.0 CRD
    Jun 2018
    Midlands
    Thanks Winco, I will give it a go.
