Results 1 to 9 of 9
Thread: Space saver for 2.7 S type XS
    chris1959rhyl
    Guest
    I have the Mercury 18" wheels on my 2007 2.7 S type XS and I don't have a spare and was looking online for one,
    I would like to know if I could get away using a 16" or 17" space saver or would it foul the brake calliper. has any one else tried ??,
    Jul 2009
    Yorkshire
    You could probably pick up the kind used on the STR quite cheaply, which would clear any of the brakes.
    The reference I have is T115/85R18 for the tyre - someone may know the rim details.
    A full size wheel does apparently fit in the boot.
    I have a full size front wheel as a spare in my STR. Fits fine with its 245x 40ZR x 18" tyre
    SE London/Kent
    Yep, a full size alloy wheel + tyre (245/40/18 ) fits in the well. Had one in my s-type tdv6.
    Jun 2013
    I've found other cars with a space-saver also have a big enough spare well for a full size wheel.
    The tight-arsed manufacturers just don't want to give you one. It would be a steel one in any case even if you have alloys.
    Some who just give you a glue can probably don't have a spare well in the boot at all?
    Nov 2012
    Carlisle
    Steel Wheels are generally lighter than their equivalent size "Alloy", the actual metals used in road car ALLOYS are not as light as those on race cars and require a lot more material than a pressed steel wheel.
    The space saver saves both SPACE and weight, so helps the manufacture reduce the overall weight.
    Current Cars
    2002 Galaxy 2.3 Ghia - State Blue
    2000 Focus 1.8 Zetec Breaker Panther black.
    1987 Sierra Sapphire 2.3 8v Project - Galaxy Blue
    2007 Transit 350-100
    Past Jaguars
    Jun 2013
    Quote Originally Posted by twin--turbo View Post
    So?
    Whose side are you on, TT?
    Have you been drinking again??!!
    No? Why not?!
    chris1959rhyl
    Guest
    Thanks all for the usfull replies. managed to pick up a 18" space saver with jack kit on ebay just waiting for it to arrive.
    Oct 2018
    Cumbria, England UK
    I tried a full size mercury 18inch in the boot, wheel fits perfect, but the black insert that holds that tools doesnt fit, it would if you shaved some of the polystyrene off though.
