Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: A New Twist On The Engine Temperature Problem
    Member RF900R's Avatar
    Dec 2018
    West Sussex
    So I had the same issue as many others on here with the temperature gauge failing to move, so I thought I'd change both the thermostat's, just to be sure sure. The oil cooler thermostat was replaced without any issues, and then onto the engine thermostat. Disconnected all the hoses, but the housing was a little b****r to shift. Eventually got the housing out and took a look inside and immediately found the reason why my engine wasn't getting up to temperature!
    Spot the difference!
  2. Likes Euan Tausney liked this post
    Oct 2018
    Harleston Norfolk
    That will solve the problem, next question, why was it taken out in the first place?
    2007 x type 2.2d S 6 speed, 132 ,000 and climbing.
    Dec 2018
    West Sussex
    That's exactly what went through my mind too! I know the previous owner was involved in a collision which has meant a new near side front end has been put on the car (he helpfully left the insurance details in the paperwork when I bought it), but this doesn't phase me, but might explain why the steering pump pulley fell off too! Probably a shoddy repair job. My mate, who's a former Ford mechanic, reckons the water pump (which has since been replaced) might've been shot and taking the stat out kept the engine running cooler.
    2006 X-Type 2.0 SE Diesel Estate: 122,000 miles and climbing!
    Heart of Gold, Nerves of Steel, Knob of Butter.
    Apr 2012
    reminds me of the old fords/vauxhalls/bl cars of the 70's as there was no computer then running the fuel mixture just you on the choke
  6. Likes WELSHGIT liked this post
  7. #5
    Jun 2012
    Hayling Island
    Problem with doing that is that it simply short cuts the coolant flow. Instead of it going around the motor, it simply takes the line of least resistance. Through the radiator usually. If you are going to do that to try and keep it cool (which won't work btw...) at least only take the guts out of the thermostat and leave the disc in...
    2005 Estate X type 2.2 Sport.
    2005 "AllyCat", 3.0 XJ6 SE.
    VFR800A and a VFR 800F
    Sure I took the Red pill....
  8. #6
    Dec 2018
    West Sussex
    That's the problem though, it did keep the engine cool. Too cool. The gauge never moved and the heater, while warm, was never getting toasty. Both problems solved with the new stat. Just waiting to see what issue pops up next, seeing as someone along the line thought it necessary to remove that stat in the first place.
  9. #7
    Jun 2012
    Hayling Island
    Unless you know the history, could have been a blocked rad to a dodgy temp gauge.
  10. #8
    Dec 2018
    West Sussex
    Just before I bought the car the radiator was replaced, so that's possibly the reason. The temperature gauge works fine so no issues there.
  11. #9
    Jun 2012
    Hayling Island
    Yes. That might well be the reason.
  12. #10
    Dec 2018
    West Sussex
    A little update - since replacing the thermostat (or in fact installing one), the mpg has gone up from 42 mpg to 50 mpg!!
  13. Likes Flaktoaster liked this post
