Page 2 of 10 FirstFirst 123456 ... LastLast
Results 11 to 20 of 91
Thread: S-Type R engine probleme when cold
  1. #11
    Dec 2018
    Switzerland
    Yes dip stick exactly, ok but we have any solution to know the level?
  2. #12
    Senior Member payno's Avatar
    birmingham
    Quote Originally Posted by Xpape View Post
    You can make one from some stiff wire and use the fill up hole by taking the fill plug out the level should be right up to the hole
    S TYPE R 2003
    BMW M3 EVOLUTION 1998
  3. #13
    Jul 2009
    Yorkshire
    That's roughly right but maybe following the official procedure would be wiser.
    It's in the Stickies (I hope!) and is quite exacting. (Note the temperature, the gear changes, etc.)
  4. #14
    Jun 2013
    Here is a video to help:
  5. #15
    Dec 2018
    Switzerland
    Thank you, so my car is a S-TYPE 2, right? Not the first one, so the torque converter is concerned? Or you think not with experience? Maybe is that but why when engine hot have nor more problem? I don't know who's causes the problem but now i'm going to see at first the oil transimission level.
    Thank you everybody
  6. #16
    Dec 2018
    Switzerland
    Hard to know precisely if transmission have the good level on this transmission... But when all gear is good i think the level is good to... Mmmmmh... I give you a picture of my car when you want, not for resolve the problem, just for community. Haven't original rim... like or not, maybe to extraordinary for a jaguar but i have buy like this. Is black and very bright!
  7. Likes payno liked this post
  8. #17
    birmingham
    We would like very much to see some pictures of your STR
    S TYPE R 2003
  9. #18
    Dec 2018
    Switzerland
    i Have just this one but i'm look for have more picture
  10. Likes payno liked this post
  11. #19
    Apr 2016
    Near Berlin
    Hi
    Do you have a code scanner?
    It would help you a lot when working and diagnosing faults.
    If you are only interested in the engine and gearbox you could use an elm327 with a program. If you want to read all the modules then an icarsoft i930 or jlr could be a good option for you.
    Do you speak German?
    Grumpy Old Git
    Napoléon Bonaparte
  12. #20
    Dec 2018
    Switzerland
    I speak better english i think, the same level of german... I speak french normaly.
    Ok i can looking for that but i haven't check engine warning light, so i can found a fault without engine light?
