Results 1 to 10 of 13
Thread: Almost new year so...
    Jun 2012
    Hayling Island
    I'm thinking naughty thoughts.
    I'm thinking I'll redo the gearbox oil change on the S type. Then do a rolling road run.
    And fit a full exhaust on it. Deleting the cats. Put a set of O2 eliminators on for the closed loop running. Then do another rolling road run.
    And keep the standard system for when it needs an MOT again.
    Legal? Barely. Chance of the car having an emission check at the road side? Next to none....
    Increase in power and torque? Possibly.
    2005 Estate X type 2.2 Sport.
    2005 "AllyCat", 3.0 XJ6 SE.
    VFR800A and a VFR 800F
    Sure I took the Red pill....
    Jun 2012
    Hayling Island
    And my wife bought me a genuine Jaguar bonnet leaper for the S type. She says it looks like it needs one. Hmm. That old chestnut again...
    Jul 2009
    Yorkshire
    If it reduces the back pressure you may get reduced power.
    Jun 2012
    Hayling Island
    Correctly designed engines don't need, or use "back pressure". That's a well rehearsed fallacy.
    There's lots of theories. But basically if the combustion process has raised the pressure within the cylinder by whatever variant of the compression ratio it was throttled to, that and the piston accelerating upwards gives more than enough momentum for the gasses to be removed. The larger the primary the better you might think? Well, it's not quite that simple. But it's simpler with a V8 because the exhaust pulses are uniform. And as these engines aren't "flat plane" big bang motors, that's an advantage.
    There's the theory about negative pressure waves, there's the theory about the gasses impinging on an exhaust driven supercharger, there's also theories about the length of the exhaust branches. These can all be "tuned" to help the motor under certain circumstances, but it's common enough knowledge that if you change the exhaust then you also change the inlet route that your fresh air or mixture "see's" as well. And the more exhaust you get rid of, potentially there's more space in tthe cylinder for the fresh charge.
    Exhausts usually add to pumping losses, that prevent the engine spinning up quickly, a lot of research has gone into this from the likes for Suzuki, Honda, Yamaha, Kawasaki, Ducati, you name it, if they build a performance engine, they go the extra mile with the exhaust as well to try and remove as much restriction as they can..
    And especially with a supecharger, you will have more energy to remove the gasses anyway, so you'd think a free flowing exhaust would be a benefit, not a hindrance..
    The only time having an exhaust too big might create a problem is if the larger bore also has a restriction in the form of a baffle type silencer.
    In fact, regarding power outputs, back in the 1960's when the major US car makers were playing the power output war, their engines used to dump their exhaust into a chamber that was as close to vaccum as possible just to remove pumping losses.
    Basically you have to work out how much gas you need to get rid of and over what rev range and size the exhaust accordingly. Generally a 4 into 1 will give more torque lower down, (and power as it's a function of torque) a 4 into 2 into 1 will give more power at the top end as the exhaust gasses are able to leave the combustion area with less restriction.
    There are very skilled people out there that know far more about this than I do.
    Jul 2009
    Yorkshire
    Let us know how it goes and what the the dyno results are (start with a "before" dyno, of course).
    Probably wise to tell your insurer.
    Won't be legal for public roads, but I suspect will pollute rather less than most of the cars on the roads - which are deemed legal. Ah, the madness of politicians.
    Apr 2016
    Near Berlin
    You will also get better mileage per gallon. I know a person who did it to his diesel van and he was saving a litre per 100 km.
    Grumpy Old Git
    Napoléon Bonaparte
    Jun 2013
    Many years ago we fitted straiht-through megaphone "silencers" to our bikes. They breathed better and I think we gained a little more power.
    It could have been wishful thinking of course, because we didn't have money to blow on power tests.
    We throttled down at night so we didn't make as much racket as the fool bikers do today with no regard for time of night nor people.
    I could quite happily swat them with a lump of 4x2.
    Jul 2009
    Yorkshire
    Being a petrol, if it reduces EGR as seems likely then the MPG will be worse and the in--cylinder temp higher. I doubt the latter matters on a 3.0.
    Not that MPG would appear to be the OP's interest.
    Before & after dynos will be interesting.
    Jun 2012
    Hayling Island
    It will still be silenced, I'm looking for the sake of discovering just how restricted the standard boxes are.
    Gearbox oil flush again first.
    Senior Member Victor's Avatar
    Aug 2006
    Dewsbury West Yorkshire
    At your age ?? well put all such thoughts out of your mind and concentrate on the motors. ..............besides, such thoughts are an overrated pastime and best left for t'young folk.
    Now behave.
    A very cynical grumpy old man
    Late 2004 2.7D auto
    Connoisseur of Fine Ales
