Results 1 to 10 of 18
Thread: S-type turbo solenoid
    Sep 2017
    Scarborough, England
    Angry S-type turbo solenoid
    I have been unable to locate the turbo solenoid/actuator on my 2005 2.7 diesel, despite having spent a couple of hours on this forum looking for info & using the several photos relating to how these items are repaired, particularly the soldering of a "dry" spot weld on an internal wire. I am doing this because I got a fault code P0046 (TC boost control solenoid circuit/open). Having read that it would take 15 minutes to remove this thing I removed the plastic engine cover expecting to instantly see something resembling the photos of the component. This did not happen, can anyone tell me where this thing is?
    Apr 2008
    Further up the creek.
    Hoya Ray,
    This is the "Hot to use the forum" section, and may not be the best place to post your technical questions?
    Try the S-Type area (you've posted there before):
    https://www.jaguarforum.com/forumdisplay.php?f=27
    2000 Jaguar X308 4.0
    1973 Jensen Interceptor Mk III 7.2
    1969 Jensen Interceptor Mk I 6.3
    Administrator Administrator's Avatar
    Oct 2004
    Antrim N.Ireland
    Thread moved to correct section... S Type
    Rory - Jaguar Forum Administrator - Help Support the Forum
    Jun 2013
    Hi Ray.
    Did you get the Workshop Manual from http://www.jagrepair.com?
    It's very detailed with diagrams for everything.
    Here's the direct link too: http://www.jagrepair.com/images/Auto...M-Workshop.pdf
    Sep 2017
    Thanks Jim. I stumbled across it yesterday & have located the component in question. I will have a crack at removing it when the weather improves.
    Senior Member Andy K's Avatar
    Oct 2008
    UK
    Where is it then?
    Sep 2017
    Where is it then?
    Sorry- the part that I was looking at (directly underneath the large rubber pipe feeding air into the plastic box at top front of engine) is evidently some kind of sensor. I will have to do more research. The diagrams in section 303-04D of the repair manual are not very clear. Any help would be welcome.
    Senior Member twostrokekid's Avatar
    Mar 2010
    Coventry, England
    There are two actuators, one on each bank of the vee attached to the turbo. I wasn't aware you could remove them with the turbo in situ but then again I've never tried. I got two changed under warranty many years ago (they failed within 3 years of new) and had to pay for the third one - all on the same (driver's) side of the car. That was £4200 paid to JLR for a sub standard piece of engineering!!
    Anyway, the following pics show you where they are mounted, the actuator is Item 7, low down at the back of the engine. The second pic shows the actuator mechanical internals. I haven't got a pic of the electrics.
    2006 S Type 2.7d Sport
    2000 Volvo V70
    1967 Triumph TR4A
  9. Thanks Andy K, Ray71 thanked for this post
  10. #9
    Mar 2010
    Coventry, England
    Just in case anyone wants the full Legend that goes with the first pic above:
    1. Throttle body
    2. Glow plug(s)
    3. EGR valve(s)
    4. Fuel injector(s)
    5. Port deactivation pneumatic actuator
    6. Volumetric control valve (fuel)
    7. Rotary electronic actuator (turbocharger)
    8. Pressure control valve (fuel)
    9. Port deactivation solenoid valve
    .............but you probably all knew that anyway!
    2000 Volvo V70
    1967 Triumph TR4A
  11. #10
    Mar 2010
    Coventry, England
    I'm on a roll, promise this is my last picture!
    2000 Volvo V70
    1967 Triumph TR4A
