Results 1 to 5 of 5
Thread: Anyone good with Part No's? Sheared a driveshaft on the XK Photos
    Member Maz_636's Avatar
    Aug 2018
    Aberdeen, Scotland
    Morning all, Happy new year.
    Not so happy for me, I managed to shear a driveshaft on the XK over the festive period. Was just driving along doing nothing out of the ordinary, pulled away from a stop, normally, not aggressively at all and lost all drive as if it had slipped in to neutral. Tried to engage drive and reverse and had no drive, just revs.
    Did a few visual checks at the side of the road and got trailered home. Long story short the O/S shaft sheared along the circlip groove inside the joint at the hub side. I dont know why but the pilot hole in the end of the shaft, that i would assume is used for keeping it true when machining, is drilled as far in as the groove which creates an obvious weak spot where there's less material.
    Anyway, I've been on the hunt for replacement shafts....thought i may as well change both and change the diff oil while im in there too. I'm having a bit of bother finding the correct shaft number though. The ones on SNG Barratt dont seem to match my chassis number. When you narrow it down to the XK and to the halfshaft assembly it states from VIN B32753, mine ends in B17967
    The part number that comes up for this is C2D42131 which superseded C2Z4812. I also found a few for sale on ebay, genuine new parts, but they are listed to fit the XJ, XF & XK. Can anyone tell me if all of these use the same shafts when paired with the 4.2 or 5.0 engines? I just want to be sure that what I order is going to fit!
    Also some photos....
    4 Wheels: 2007 Jaguar XK 4.2 V8
    2 Wheels: 2016 60th Anniversary Yamaha R1 / 2014 Honda Grom
    There are 10 kinds of people in this world, those that can read binary, and those that can't.
    Aug 2018
    Aberdeen, Scotland
    Worth noting im going to give Barratts a call at lunch time to see if they can help as well.
    Dec 2018
    Hi I'm a new member with a xkr supercharge 2004 can any one tel me where I can find the plug in port for the computer to give me a read out on a fault thanks
    Aug 2018
    Aberdeen, Scotland
    Quote Originally Posted by Fitchy321 View Post
    Jimbov8 already answered you in another thread.
    Welcome to the forum Fitchy. Run your hand down the right hand edge of the dash roughly where your right knee would be and you’ll find it.
  5. Thanks Jimbov8 thanked for this post
    Likes Jimbov8 liked this post
  6. #5
    Aug 2018
    Aberdeen, Scotland
    So Barratts have given me part numbers based on my VIN...
    C2P3968 & C2P3969
    Searching on google these appear to be the part numbers for use on S Type jags and various XJ and XK models from 2007-2009, I'll try to copy and paste the list...
    S-Type. XKR. XK. 3.0l. 4.2l. Right. 2007-09. From vin g41512, all. Without supercharger. All from vin n41581, all from vin n41581
    2008 Jaguar S-Type Base, R 3.0L V6 - Gas, 4.2L V8 - Gas
    2007 Jaguar S-Type Base, R 3.0L V6 - Gas, 4.2L V8 - Gas
    2006 Jaguar S-Type Base, R, VDP Edition 3.0L V6 - Gas, 4.2L V8 - Gas
    2005 Jaguar S-Type Base, R, Sport 3.0L V6 - Gas, 4.2L V8 - Gas
    2004 Jaguar S-Type Base, R 3.0L V6 - Gas, 4.2L V8 - Gas
    2009 Jaguar Super V8 Base 4.2L V8 - Gas
    2008 Jaguar Super V8 Base 4.2L V8 - Gas
    2007 Jaguar Super V8 Base 4.2L V8 - Gas
    2006 Jaguar Super V8 Base, Portfolio 4.2L V8 - Gas
    2005 Jaguar Super V8 Base 4.2L V8 - Gas
    2009 Jaguar Vanden Plas Base 4.2L V8 - Gas
    2008 Jaguar Vanden Plas Base 4.2L V8 - Gas
    2007 Jaguar Vanden Plas Base 4.2L V8 - Gas
    2006 Jaguar Vanden Plas Base 4.2L V8 - Gas
    2005 Jaguar Vanden Plas Base 4.2L V8 - Gas
    2009 Jaguar XJ8 Base, L 4.2L V8 - Gas
    2008 Jaguar XJ8 Base, L 4.2L V8 - Gas
    2007 Jaguar XJ8 Base, L 4.2L V8 - Gas
    2006 Jaguar XJ8 Base, L 4.2L V8 - Gas
    2005 Jaguar XJ8 Base, L 4.2L V8 - Gas
    2009 Jaguar XJR Base 4.2L V8 - Gas
    2008 Jaguar XJR Base 4.2L V8 - Gas
    2007 Jaguar XJR Base 4.2L V8 - Gas
    2006 Jaguar XJR Base 4.2L V8 - Gas
    2005 Jaguar XJR Base 4.2L V8 - Gas
    2009 Jaguar XK Base 4.2L V8 - Gas
    2008 Jaguar XK Base 4.2L V8 - Gas
    2007 Jaguar XK Base 4.2L V8 - Gas
    2009 Jaguar XKR Base, Portfolio 4.2L V8 - Gas
    2008 Jaguar XKR Base, Portfolio 4.2L V8 - Gas
    2007 Jaguar XKR Base 4.2L V8 - Gas
  7. Likes fat controller liked this post
