Results 1 to 4 of 4
Thread: jaguar s-type XS 2007 2.7 squeaky suspension
    chris1959rhyl
    Guest
    Got an annoying squeak comming from the Nearside front suspension. most noticable on uneven roads and around town. Sounds like its behind the wheel somewere. Any suggestions ?
    Apr 2016
    Near Berlin
    Here is now to check the suspension
    Grumpy Old Git
    Napoléon Bonaparte
  3. Likes Lost it liked this post
    Jun 2012
    Hayling Island
    When I found that video I recall watching my car being MOT'd and they used the usual lever to check the bottom joints on the front, told me there had been a bulletin years ago about the bottom ball joint shearing... So they didn't use the grips method, which they can't in this country, not many test bays use whel free ramps because if the chassis is corroded they need to be able to see it, lifting the car on the chassis wouldn't do at all so consequently there isn't the physical space to get the grips in.
    Although to be fair the "Wheel shaker" plate they have these days does load everything quite well.
    2005 Estate X type 2.2 Sport.
    2005 "AllyCat", 3.0 XJ6 SE.
    VFR800A and a VFR 800F
    Sure I took the Red pill....
    Jun 2013
    Quote Originally Posted by chris1959rhyl View Post
    Probably one of the lower bushes.
