I've been meaning to start this thread for a very long time, better late than never.
I own a LWB X350 Super V8, but a lot of the Info you'll find in here will be equally helpful to all X350 & X358 models.
In some cases it may even help those who own other models of Jaguar.
I often read or see many threads that are fundamentally asking the same question, the purpose of this thread is to allow visitors to access what I and others have done, quickly.
If you have a thread detailing an issue and outcome, especially if it has images showing how to, please let me know and I'll gladly add it to this.
The links below will direct you to another thread, either at the beginning or the page where the fix begins. Reading from these points should allow you to see the whole fix, not everything is documented on the same post or page.
Jaguar Manuals - For Anything & Everything Jaguar, available on PDF
Jaguar Classic Parts - X350 / 358 Catalogue
Understanding The Long Jaguar Part No - 2W93-19D629-DD, etc
JagRepair.com - Another source For Anything & Everything Jaguar. Repairs, TSB's, OBD codes, etc, etc
Jaguar Technical Specifications - All Jaguars to 2010MY
Things I've done
F Pace Alloys - On an X350? They'll never fit? YES they do 😁
Headlining Renewal Posts 692, 699, 712, 724 & 762 - Workshop Manual Page 5675 for removal procedure
DIY Car Ramps Post 22 onward
Engine Oil Change Post 26, (FYI I now use Ford Formula F 5W30 Fully Synthetic, purchasing 20L at a time)
Differential Oil Change Post 513
Front Wheel Bearing Assembly Renewal Posts 455 & 464
Earth Stud Renewal - The 3 Behind the Headlights Posts 259 & 269
Wing Mirror Puddle Lamp Renewal Post 44
Sidelight Bulb Renewal Post 8
Rear Door Card Removal Post 91 (Removal of Fronts similar)
Rear Doors Locked Posts 82 & 51 (My mechanical Issue)
Door Interior Opening Handles - Posts 90 & 91 (Broken Spring)
The Valley Pipes - The 4.2L S/C V8's Achilles Heel Post 102
Windows Global Opening/Closing Reset Post 122
Front Seat Removal Post 196
Misfire Codes P0301 to P0308 on a V8
AC Compressor Renewal Posts 314, 327 & 331
Windscreen Washer Pump Renewal Posts 421 & 430
Caldoofy MOD - 4.2L S/C V8 Post 1099
MAF Sensor Removal and Clean 4.2L S/C V8 Post 1099
SRS System - B2292 Drivers Seatbelt Pretensioner
Fuel Filter Renewal - Post 1277
Windscreen Drainage - Post 1226 Keep clean or suffer the consequences
Lower Mesh Grille MOD - My Adaptation, more Stealth
Supercharger Oil Change - Post 1424
Rubber, The Coolant Variety - Full Renewal - How to - Post 1564 for the beginning
Secondary Air Injection Pump - The Hunt for the cause of P2444
Air Suspension Compressor Renewal - How to with images
Changing the Boot/Trunk Lid Release Button
Door Speaker Fix
Things Others have done
JagDroid - Touchscreen Upgrade - Where it ALL began
ACM - Audio Control Module - Installation (Guide includes Centre Console & Head Unit removal)
Air Suspension - A Tale of Dogged Determination - Post 200 for the Outcome
Headlining Renewal
Earth Stud Renewal - The 3 Behind the Headlights Post 99
Wing Mirror Puddle Lamp Renewal Post 8
MAF Sensor 2.7 TDVI Removal & Clean
Front Door Card Removal (Removal of Rears similar)
Bonnet/Hood Cable Release Post 9 - Reasons for and how to gain access
ACC Adaptive Cruise Repair
Blower Fan Removal & Clean
Fuel Pump Drive Belt 2.7 TDVI Renewal
Alternator 2.7 TDVI Replacement
Auxiliary Input via Radio/Cassette
Bosch AeroTwin AR608S Mod - More Water - Post 63
X350 driver’s window regulator cable repair
N/A V8 Spark Plug Change
TBC and added to this post
Things I've done
Door Speaker Fix
Headlining Renewal
