Results 1 to 10 of 14
Thread: S Type 2.7 Auto Gearbox Leak
    Oct 2018
    Cumbria, England UK
    Hi, I have a slight oil leak from the bellhousing on my auto gearbox (2.7D 6 Speed Auto), suspecting the seal where torque converter slides in, has anyone changed one of these? Hoping its just Gearbox out, pull torque converter out, change seal & back together with new oil & filter. Also have Vibration from Propshaft at 50-60 MPH, but thought while gearbox out could send prop to get balanced.
    Many Thanks
    Chris.
    Senior Member Andy K's Avatar
    Oct 2008
    UK
    not the the connector sleeve leak at the other end which is easier?
    XJR 2001 Pacific Blue
  3. Thanks Chris45uk thanked for this post
    Oct 2018
    Cumbria, England UK
    Took the rubber plug out of bottom of bellhousing and can see where oil has been running down from behind torque converter, I had engine and gearbox out in the summer, to do complete engine rebuild (had snapped crankshaft when i bought it), i didn't take torque converter out of gearbox, thought it best not to disturb, thinking back, the car had sat for 2 years, maybe I should have changed it.
    Oct 2008
    UK
    Where did you get the crank from?
  6. #5
    Oct 2018
    Cumbria, England UK
  7. Thanks Andy K thanked for this post
  8. #6
    Oct 2018
    Cumbria, England UK
    Same engine as Landrover Discovery 3 2.7, got main, big end bearings, piston rings, timing chains & gaskets from same company. only things that are different on jag is turbo gaskets & lower small sump gasket.
  9. #7
    Oct 2008
    UK
    How many miles/weeks had it been running?
  10. #8
    Jun 2012
    Hayling Island
    I think what is more to the point is that if the old crank had snapped in the "usual place" the torque converter itself would have been supported by just the bearing in the t/c. Not designed for that, the seal would have taken a beating. So yes, more than likely it will be just that one seal?
    2005 Estate X type 2.2 Sport.
    2005 "AllyCat", 3.0 XJ6 SE.
    VFR800A and a VFR 800F
    Sure I took the Red pill....
  11. Thanks Chris45uk thanked for this post
    Likes Chris45uk liked this post
  12. #9
    Oct 2018
    Cumbria, England UK
    Crankshaft broken at 10800 miles, done 2500 miles since engine rebuild and all ok.
  13. #10
    Oct 2018
    Cumbria, England UK
    Good point, the crank had broken near the back, I didn't think of that one.
