Results 1 to 5 of 5
Thread: Cigar lighter/socket
    Senior Member merlin's Avatar
    Nov 2010
    Hertfordshire
    Hi all.
    I'm stuck on this one and could do with your brain power.
    Just noticed the illumination to the front ashtray (used for keeping coins in) is not working, also the cigar lighter (decoration only) will not stay pushed in, it does glow if I hold it in which suggests power is there, but no joy otherwise, I have checked the relevant fuses which are all ok, is the illumination a bulb or an led? has the cigar lighter itself broken? I know it's a trivial thing but fussy, fussy, fussy about these things.
    merlin
    And Then-----As if by Magic!
    2005 - S-Type 2.7d -Auto
    The light is an LED so unless you have any other lights not working I would suspect the LED being defective. Fuse F56 20A in the rear distribution box is for the lighter as is relay R10 in the same box.
  3. Likes payno liked this post
    Senior Member payno's Avatar
    birmingham
    There are a couple of metal strips in the cigarette lighter socket that grip on to the push in bit and expand as it heats up and allow it to pop out when hot enough you just need to bent them back out slightly to get it to work again
    S TYPE R 2003
    BMW M3 EVOLUTION 1998
  5. Likes Jimbov8 liked this post
    Nov 2010
    Hertfordshire
    Thanks Jim/Payno
    all the fuses have checked out ok, I don't know how to check out a relay!
    I will have a look at the metal strips in the lighter payno as I had been using it for my tyre compressor (perhaps strained it a bit) is there an easy way to locate the led illuminator without pulling the car half to bit's??
    merlin
  7. #5
    Jun 2012
    Hayling Island
    Personally I'd disconnect it. If you keep coins in the ash tray, well a 1p coin will just fit in the hole left when the cigar lighter is not inserted. Ask me how I know this.... Or at least leave something n the hole.
    2005 Estate X type 2.2 Sport.
    2005 "AllyCat", 3.0 XJ6 SE.
    VFR800A and a VFR 800F
    Sure I took the Red pill....
