Results 1 to 5 of 5
Thread: Drivers door issue when below zero
    Senior Member coling's Avatar
    Scotland
    Angry Drivers door issue when below zero
    Evening
    So the issue I had just before Christmas with the battery and drivers door entry has given me a problem a further twice.
    To clarify the battery has been fine since charging, twice now when the temperature has fallen below zero Iíve been unable to get in via drivers door in the morning, most annoying!
    It feels like the door is locked from the outside, but can be opened from the inside of the car. Any thoughts? Feels like something frosted up? As is fine again when the temperature rises...
    As itís likely to be below zero quite regularly over the next few months I donít much fancy having to resort to climbing through back door to gain access, the passengers door was fine today but wasnít on the 2 other occasions and rear doors have not been a problem at all.
    Colin.
    XJ X351 5.0 V8 Portfolio, Black 2011 17k
    https://www.jaguarforum.com/showthread.php?t=111207
    Range Rover Vogue, 4.2 V8 Supercharged, Grey '08 80k
    http://bit.ly/2kB60lW
    Previously
    XJ X358 2.7Tdvi Sovereign, Vapour Grey '08 70k
    http://www.jaguarforum.com/showthread.php?t=98612
    X Type Sport, 3.0 V6, Racing Green '03 plate 80k.
    http://www.jaguarforum.co.uk/f69/my-3-0-x-48345.html
    It sounds like the door lock mechanism is starting to fail.
    2010 Jaguar XF 3.0 D
  3. Thanks coling thanked for this post
    Senior Member jasz1156's Avatar
    Apr 2014
    New zealand
    Sounds like driver door switches for locks. See sticky on replacement by The Boy in stickies.
    White XJL portfolio 3 litre s/c ecu to S MY2015
  5. Thanks coling thanked for this post
    May 2017
    Brackley, UK
    Yup, symptoms match the failing door lock motor. If you're inside when it plays up, you can see it tries to unlock, and you can see the lock lever on the door move, but not quite enough.
    If its noticably worse on very cold days, the battery is also probably struggling, due to reduced effeciency. Its possible a new batt may mask the door motor fault, but it will only get worse and fail.
    2010 XJ Portfolio running on lorry fuel. I know, Jag Diesel is just wrong!
  7. Thanks coling thanked for this post
    Likes coling liked this post
    Dislikes coling disliked this post
  8. #5
    Scotland
    Quote Originally Posted by TheBoy View Post
    Thanks for the this, will look into replacing and use your stick as ref. Sorry for the dislike, fat fingers on small iPhone keyboard!
    Previously
