Results 1 to 10 of 10
Thread: N/S rear suspension arm boot deteriorated
    Dec 2016
    Essex
    Good morning,
    Happy Friday all. I'm off to look at a 2003 4.2 SE, an a cursory glance at the last MOT tells me "N/S rear suspension arm boot deteriorated". My immediate question is, how much am I looking at to repair this (so I can negotiate a price discount), if it hasn't already been done?
    Many thanks,
    Thomas
    2003 Jaguar XJ8 (X350) 4.2 Silver
    2006 Jaguar XK (X150) 4.2 Indigo Metallic
    Jun 2017
    Kent
    If it means the driveshaft boot then KwickFit will replace it for £80 from memory - or they do for the front driveshaft boots on other cars I've had. They cut the old one off, remove the driveshaft end from the hub and stretch a new one over the CV joint and reasemble.
    Senior Member dbug's Avatar
    Oct 2011
    Northants
    Bad advice re Kwikfit - see customer reviews - https://uk.trustpilot.com/review/kwikfit.co.uk?page=4
    Personally wouldn't trust their cowboys with a kids pedal car. Remember the old Kwikfit ad -"there's nothing worse than a Kwikfit fitter"
    XJ 5.0V8 Portfolio, Mondeo Estate 2.0TDCi, '67 Triumph TR4A
    Jun 2017
    Kent
    Same old same response there. I don't generally advocate Kwikfit either but on a job that only consists of removing a couple of bolts and doing up again a there is little they can get wrong and if they do, you get them to sort it out - you will know within 3 seconds if your driveshaft bolt has not been refitted.
    Regarding using social media to gauge if a multinational company with hundreds of garages up and down can do a simple job. It's a well known fact that many more people will complain than leave positive comments.
    Just a thought,
    But if this is something that seems as straightforward as suggested, is it not a DIY job?
    2006MY Super V8 LWB
    Midnight Black with Ivory & Black Suedecloth Headlining
    All options except Sunroof
    Longlife Exhaust & a Caldoofy - Waft 'N' Loud
    Bespoke Sheepskin Rugs
    Nextbase Duo Dashcam
    2008MY LR Discovery 3 HSE V6 2.7TD
    Jun 2017
    Kent
    Not easy without a special tool to stretch the boot over the CV joint. The boot opening is about 1inch across, you have to get it over a 3inch CV joint. You ideally need a compressed air boot spreader/stretcher.
  7. Thanks Ashanti thanked for this post
  8. #7
    One for the Indy then, should mine ever need doing.
    Thanks for the heads up.
    2006MY Super V8 LWB
  9. #8
    Dec 2016
    Essex
    Update, I fell in love with the car on the test drive and bought it. So, that's two V8 cats I own now...
  10. Likes Milowokie liked this post
  11. #9
    Oct 2011
    Northants
    Quote Originally Posted by RimmerJag View Post
    Don't like to admit it, but a few years back, against my better judgement, used Kwikfit for two simple jobs - one recharge air con and other supply. fit and balance new tyre. They managed to f*** up both jobs. So I also can talk from personal experience.
    To the OP good luck with your new purchase, enjoy - SWMBO still prefers my old X350 to my X351.
  12. #10
    Oct 2016
    Northumberland
    There are several boots......
    Driveshaft CV boots - in which case, but a Jaguar one and re-fit it properly, the stretch-over-the-top ones are a typical garage bodge to make it easy
    Lower wishbone inner pivot bush boot - these have a separate cover boot - so you're looking at a lower wishbone
    Upper wishbone inner or outer boot - same story, you're looking at a new wishbone
    track control arm boot - one at both ends, but the new arm comes complete.
    My advice would be to budget for £300 so you have the most expensive covered.
    ...... but then again, if its the lower wishbone, I would only replace in a pair
