Results 1 to 10 of 12
Thread: Lights suddenly stopped working
    Senior Member Nezzer's Avatar
    Feb 2016
    Midlands
    My lights have suddenly stopped working. Nothing happens when I turn the switch to position I or II - unless I pull it out to the foglight position when they come on in position II. The main beam on the stalk works OK. Surely this can't be related to my recent key fob change? It started happening after that...
    2002, 2.1 Manual Sport, 58,000, BRG... Retrofit: 18' Proteus wheels/Avon ZZ5's, Brembo pads & discs, braided hoses. Parrot Asteroid Smart. Electric rear windows, powerfold mirrors, premium speakers, hardwired Nextbase dash cam.
    Senior Member rchiv's Avatar
    Feb 2013
    Orpington, Kent
    Sounds like switch problem to me. Try removing the switch and liberally spraying switch cleaner in it and toggle back and forward a few times. Dirt can build up between the switch components.
    I would not think for a moment that it has anything to do with a fob change.
    2006 X Type 2.2d SE Manual Estate. Zurcon Blue Champagne/Mocca, F/R Parking sensors, ,Auto Lights, Auto Wipers, Headlight Washers, Sat Nav 2012 update, 17 in Wheels, 116K Mods:- Electric Autofold Mirrors on Locking
  3. Likes Mr Squirrel liked this post
    Feb 2016
    Midlands
    Quote Originally Posted by rchiv View Post
    Hi Roger, thanks for that - I gave it a try but the problem persists. It's odd because the dash lights up, as does the switch, in fact, everything is as normal - except the lights don't work!
    Jul 2007
    North Norfolk
    This sounds like it could be your backup alarm sounder is faulty and blowing fuse f67 or f75. The sounder has an internal rechargeable battery it's known for it to blow the fuse which causes various symptoms (dependant on year/model of x-type) like no headlights.
    If the fuse is replaced and it blows again, then unplug sounder and replace the fuse again. This should prove the point.
    The sounder and plug location is behind the liner under the left front wing and can be seen in this post:
    https://www.jaguarforum.com/showthre...l=1#post613205
    (EX) '06 2.0D SE Estate
  6. #5
    Feb 2013
    Orpington, Kent
    The OP says that they come on when he selects the fog lights so the fuse cannot have blown.
  7. Likes jimbo20 liked this post
  8. #6
    Jul 2007
    North Norfolk
    The fuse F67 (or f75 on some models) is only ( I think) 5A. It doesn't directly supply the power to the headlights, but to various other support items, eg relays etc. I remember seeing here that depending on the exact year and options fitted certain functions won't work in certain circumstances when that fuse is blown.
    You are right in that the problem could also be caused simply by a faulty switch though.
  9. Likes rchiv liked this post
  10. #7
    Feb 2016
    Midlands
    Quote Originally Posted by jimbo20 View Post
    So, I may well have caused this while messing about with my key perhaps? Unlocking/locking the car using the fob without a transponder in it...It seems an unusual coincidence that the problem started after the key fob change
  11. #8
    Senior Member dh50's Avatar
    May 2015
    pickering north yorkshire
    what about the earth point behind the nearside light , had a similar but not exact problem once, to check i fixed a length of wire from the earth point on the light to a bright part of chassis or negative lead on the battery and lights worked. i think there's two maybe three earth points behind that light that can cause problems
    x type 3.0 auto sovereign and kawasaki zx10r
  12. #9
    Feb 2016
    Midlands
    Where is the fuse located? Glovebox or engine compartment?
  13. #10
    Fuse F67 5A is located in the central junction fuse box though if that has blown you would have lost quite a few other circuits.
