Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 2000 S Type CATS fault: where is SCP diagnostic connector FC001 located?
    Sep 2016
    Parksville, Canada
    I am still trying to track down the source of a problem with the CATS suspension damping system on my 2000 S Type.
    The 1999 manual on page 4145 [J2, J3] tells me to check the diagnostic connector FC001 , pin 2 for resistance to ground and to the BATTERY pin 2.
    I will give the manual another go around but I thought I would ask if anybody can point me to where the SCP [what does that abbreviation stand for?] and its diagnostic connector are to be found physically on the car.
    Bob
    Dec 2013
    Berkshire
    SCP means "Standard Corporate Protocol"
    It is medium speed computer network, in this case a twisted pair (usually blue and yellow), the CATS module is connected to the SCP.
    The electrical manual usually gives physical locations for all connectors and modules etc.
    S Type 4.2 SE Plus 2002 original spec: Xenon HID/SatNav/Voice/Cassette Player/CDC/TV/GSM Phone/Sun Roof/Rear Blind/CATS.
    Retro-fitted: CD Player/Bluetooth Phone/Aux Power Socket, USB & Volt Meter in Boot/Reversing Cam/Dash Cam & PSU/Dual USB sockets in Armrest/
    Pictures of technical stuff
    Jun 2012
    Hayling Island
    2005 Estate X type 2.2 Sport.
    2005 "AllyCat", 3.0 XJ6 SE.
    VFR800A and a VFR 800F
    Sure I took the Red pill....
    Sep 2016
    Parksville, Canada
    Thanks for your quick replay Graham. So now I understand that when I am told to check the SCP I should not be looking for a module but rather a wiring harness. The connectors to the ADCM module are blue and grey in colour. Should I take it that the 'diagnostic connector' is simply one of the two connectors that connect the Standard Corporate Protocol wiring harness to the ADCM module? Am I getting it?
    Bob
    Sep 2016
    Parksville, Canada
    I probably have this already, Lost it. I have been regularly messaging ducmon and he has been a real help.
    Dec 2013
    Berkshire
    When you find the electrical manual do a search on FC001 and it should describe it's location, colour and number of pins. It is just possible that it is the OBD connector itself.
    To work the SCP has two resistors as described above to hold one wire high and the other low (can't remember which way round), these are in network terminating modules - the CATS may even be one of them.
    You are in effect checking both wiring AND terminating modules as the latter must be connected and the wiring good as either could be the cause of comms problems
  7. Thanks muskox3437 thanked for this post
  8. #7
    Dec 2013
    Berkshire
    Updated my previous post
  9. #8
    Jul 2009
    Yorkshire
    It's probably FC1 in the elec. guide and yes it looks like the DLC (the OBD II socket).
    Pin 2 is SCP+, pin 10 is SCP-
    You can pick up SCP+ and SCP- lots of places.
    Do you think you have an SCP bus fault? They do happen but not often.
  10. #9
    Sep 2016
    Parksville, Canada
    translation from English to Canadian
    You are hovering on the edge of my competence with computer analysis and the differences between English terminology and Canadian terminology. I read that you are saying pin 2 is positive and pin ten is negative, which is what I am taking from the manual And that FC1 might be part of the OBD II socket. Trying to learn here!
    Bob
  11. #10
    Dec 2013
    Berkshire
    What are the symptoms and fault codes ?
