Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: Question for the CTEK geeks out there.
  1. #11
    Senior Member Daverichardson's Avatar
    Feb 2014
    Newcastle upon Tyne
    I have certainly never heard any high pitched whine from mine.
    But then again, we have bats around our house. I used to hear their high pitched sound, but haven’t heard it for years. I guess my ears can no longer hear that frequency, but what I don’t hear I don’t worry about!
    2006 XK Indigo Blue with Caramel seats and Sable carpets
  2. #12
    Quote Originally Posted by Daverichardson View Post
    I get a high pitched whine around the house all the time. You think I would get used to it after 40 years of marriage.
    To see index of "Franks Story" up to 8th March 2017 Please Click Here. Thanks!
  3. #13
    May 2007
    Ashford, Middlesex
    Perfectly normal for a switched mode power supply It is purely HF noise.
    I am fortunate (or unfortunate as you may see it) that I have very sensitive hearing, and despite being that bit more mature nowadays, I still have the ability to hear some very high frequencies indeed - in fact, if it were to be making its noise, I could take Mrs C into the room and ask her to listen to it, and she would not even hear it.
  4. Likes Jim_S-V6_2004 liked this post
  5. #14
    Member Marco Polo's Avatar
    Cheshire
    Quote Originally Posted by frankc View Post
    At this time of year I put my CTEK in the boot and connect it using their quick connector. My pref is using the Charge/Recon setting. Love the idea of just plugging it in and not having to check on it. Old fashioned chargers could actually cause the battery to almost boil or at least ruin the plates.
    Regarding the high pitched whine. Id send off an email to CTEK and ask them about it. Does not sound normal to me.
    Like you, Frank, I used to use my CTEK with the Recon setting on together with the Normal Battery Program setting until I read the post from Alan Jan-Janin on the XKEC forum.
    https://www.xkec.co.uk/xkforum/viewt...dition#p259702
    I then read the manual - CTEK do say in the section on Charging Programs, only to use Recon mode once every 12 months. I was concerned about the possibility of damage being caused by prolonged use of the higher voltage, so now only regularly use the Normal Battery Program. I've been doing this for over 3 years now - works fine for me with a Varta battery that was in my 2011 XKR when I bought it in June 2015. I'm only doing 3000 miles a year, mostly short local trips.
    Marco
  6. Thanks Ashanti thanked for this post
  7. #15
    Quote Originally Posted by Marco Polo View Post
    Marco
    Good advice. I only use my CTEK once a year anyway. When the weather forecast is bad, expecting snow etc or I know I am not going to be using the car for a while I stick the CTEK on there. The good thing about the CTEK is that it does not just charge/recon the battery but also monitors its condition. However you have made a valid point and I will check up on that.
    I too do only 3000 a year in mine. A Varta battery user too!
    Update. Just been on to the CTEK website and every relevant PDF I can find and I have found nothing about not leaving it on recon or not using it very often. Perhaps the article that Alan took the extract from refers to an old setup? This is just one of the many PDF's I read about https://www.ctek.com/storage/ma/ae8f...nual-UK-EN.pdf
  8. Thanks Ashanti thanked for this post
  9. #16
    Senior Member Poundy's Avatar
    Oct 2013
    Alvechurch
    Hi Frank,
    The PDF's say to use once a year, I agree it doesn't say you cannot use it more often but the fact that it boosts the charge to 15.8V might be counter productive with regular use, dunno.
    It says it helps get rid of sulphation and is for wet plate batteries, which would make it unsuitable for AGM Glass Mat batteries but then goes on to show a AGM/RECON step on the chart ???? I just use mine on Normal or AGM whichever car I have hooked up.
    I have been using Ctek for many years and when I was out of the country for 4 months had 2 cars left hooked up while away and the batteries were in top condition when I got back. Of course with all the safety features on them if anything starts going wrong they just shut down
    64 Plate RSport 3.0D All Black, Ceramic coated, self healing front car wrap, 19" alloys
  10. Likes fat controller, frankc liked this post
  11. #17
    Apr 2017
    Milton Keynes
    I'm not really sure what battery conditioning can be done to any batteries after the standard wet plate types.
    You can still buy desulfators / desulphators , spell check doesn't like either of those ........
    They basically give the battery a jolt of high voltage periodically in order vibrate the lead / sulphur from the plates.
    I'm guessing this is what the CTEK was doing in the early days of introduction but in a modern way.
    https://www.ebay.co.uk/itm/Battery-D...-/142950567993
    2009 X358 XJ LWB 2.7 Tdvi , Liquid Silver , 100k+ and going strong.
    Bumper reflectors drilled and fitted with 3W side marker lights.
    Fog lamps / DRL running with HID colour match of dipped beam.
  12. Likes frankc, Poundy liked this post
  13. #18
    Oct 2013
    Alvechurch
    Quote Originally Posted by FastEddie View Post
    I agree, and presume it wouldn't be applicable to a Absorbed Glass Mat battery, as there would be nothing to vibrate it from. I fired a email of to CTEK will see what they come back with lol!
  14. #19
    Senior Member Engineer's Avatar
    Aug 2010
    London
    Stage 1 is for desulfation which is fine to use on AGM batteries.
    Stage 6 recon is for acid stratification which some experts say AGM batteries don't suffer from, but CTEK do have it as an option
    “If you see a gap and don't go for it, you are no longer a racing driver”
    JAGUAR STR
  15. Likes Jim_S-V6_2004 liked this post
  16. #20
    Oct 2013
    Alvechurch
    Quote Originally Posted by Engineer View Post
    Confusing that they list the AGM RECON on the Charging Programs & Options Combination page, when there isn't a mode setting to get to it. I can only presume it is what happens if an AGM battery is connected and then the normal recon mode is selected. It's not a mode I am likely to use with my AGM battery but you cannot have too much information
    It also lists Normal mode for Many AGM batteries
    Then AGM for most AGM batteries like Optima etc. So what's that all about then?
