Results 1 to 10 of 10
Thread: 2010 Jaguar XJ X351 Starting Issue
    Junior Member Pandamonium's Avatar
    Jan 2019
    Liverpool
    I have a 2010 Jaguar XJ X351 which won’t start.
    I’ve literally checked every fuse but all are fine so wondered where the starter relay is located?
    The battery is charged and I’ve even tried connecting jump leads just incase.
    The ignition lights all come on when the start button is pressed but it just won’t crank.
    It was fine when it was last switched off though.
    Can anyone shed any light on this for me please?
    How old is the battery?
    I would get this checked first.If the battery checks out o.k. I would then be looking at the starter motor.
    2010 Jaguar XF 3.0 D
    Senior Member Corbeliere's Avatar
    Nov 2008
    Europe
    Could it be the switch on the brake pedal that has failed. You could try giving the brake pedal a firmer press to see if that works. Good luck.
    Train hard, fight easy.
    Black on Ivory 5.0 Stratstone 'Le Mans' special edition XFR.
    May 2017
    Brackley, UK
    If you have pumped the brakes, you will have to press the brake pedal *really* hard. Try that, and also check rear brake lights come on.
    2010 XJ Portfolio running on lorry fuel. I know, Jag Diesel is just wrong!
    Aug 2012
    Wirral
    Which engine?
    Jan 2019
    Liverpool
    Iíve tried that but no joy 😢
    Jan 2019
    Liverpool
    3.0 Diesel
    Jan 2019
    Liverpool
    The battery was flat cos itís been left standing but itís charged up fine and Iíve also tried connecting jump leads as well just incase but still no joy. Thanks for your reply
    Jan 2019
    Liverpool
    Iíve tried pressing the brake pedal really hard and the brake lights are working but it still isnít cranking. Thanks for your reply
    Dec 2018
    North East England
    Sometimes a flat battery drains the onboard computer...It can take a while for it to kick into operation again ?
    Quote Originally Posted by Pandamonium View Post
    The battery was flat cos it’s been left standing but it’s charged up fine and I’ve also tried connecting jump leads as well just incase but still no joy. Thanks for your reply
