Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
Thread: XF Corrosion on Multi pin plug in the drivers footwell
    Jan 2019
    UK Mansfield
    Hi I'm new to this site but thought Id give a go for some advice.
    5 months ago I purchased a XF Portfolio s 3.0D V6, drives fine until last Thursday. Parking brake, gearbox and engine warning light and the DSC all came on. Just the Parking Brakelight now though.
    Taken it to Jag/Tech in Nottingham today and they said a multi pin plug in the Control unit fuse box has corroded and the housing. £1300 to repair.
    Car drives fine but has these warning lights..
    Any cheaper options to sort? Any advice would be appreciated.
    cheers Rob
    Nov 2008
    Hampshire
    What year is your XF?
    Current Car:
    Previous Cars:
    2000 S-Type 3.0L SE Auto
    2007 XK x150 4.2L Coupe
    Resident Super Moderator.
    Senior Member Poundy's Avatar
    Oct 2013
    Alvechurch
    I presume it is the late X250 model 2011/2015 and suffering from the water ingress to the CJB via the faulty washer pump and capillary action up the loom to the C5 connector, top left.
    Unfortunately most facelift models are likely to be affected as the pump ages and gets more use, unless action's been taken by changing to the new updated pump before it rears it's ugly head. Some members have already done this and it's well documented on the X250 forum.
    Jaguar have issued a TSB on it but they will only fix it for free if a warranty is in place, they have no interest in taking proactive action by changing the £70 washer pump before the problem arises to save the high cost repair.
    Your fix will require a new CJB, Washer pump and the connecting wiring loom. It's a pretty straight forward job and any decent Jag Spec indy should be able to do it for a lot less than the dealers are quoting. You know what needs doing now so run it by a few and get a price, of course if you have only had the car 5 months, unless you bought it private the supplying dealer should have the onus thrown back on them to fix it, start getting a bit cranky with them sold a car with a known fault, not fit for service etc good luck.
    64 Plate RSport 3.0D All Black, Ceramic coated, self healing front car wrap, 19" alloys
    Nov 2008
    Hampshire
    Moved to X250 XF section.
    Current Car:
    Previous Cars:
    Jan 2019
    UK Mansfield
    Quote Originally Posted by Ian D View Post
    Hi Its a 2011 facelift model
    Jan 2019
    UK Mansfield
    Hi Poundy
    Thanks for your reply. That appears to be exactly the problem.
    I've emailed the seller Maxmotors2 and quoted Consumer Act 2015 so awaiting the response.
    Cheers Rob
    Jan 2019
    UK Mansfield
    Hi Ian
    cheers Rob
    Oct 2013
    Alvechurch
    Quote Originally Posted by Holmesrob View Post
    Hi Poundy
    Cheers Rob
    They seem to get some decent reviews as a seller, so if it was me I would give them a bell or call in and get them to commit to a fix or pay the dealer bill.
    Keep us informed
    Jan 2010
    Isle of Wight
    I have a 2011 XF , i assume pre face lift as it has older style around headlights. Is this at risk too?
    Senior Member johnw777's Avatar
    Feb 2016
    Southend on Sea, ESSEX
    Quote Originally Posted by Adge43 View Post
    Seems to be only the facelift model has the problem.
    2009 XF 3.0 Diesel S Portfolio
    2005 2.2 D Estate (soon to be for sale).
  11. Thanks Adge43 thanked for this post
