Results 1 to 10 of 11
Thread: Brown trouser moment with my new XF
    May 2016
    Crikey, a scary moment! Just collected a good used 2012 XF 2.2 sport diesel from an AA approved dealer in Hinckley. Immediately filled up with BP ultimate diesel and set off home to Nottingham at a sedate pace, 55-60 on M69, all was well. On M1 went through the long 50 mph restricted area on cruise control and then lifted it to 65 mph but had to pass some trucks just before Trowel services, put the foot down a bit (not floored) and suddenly, Restricted Performance Red light on, felt like engine cut out. It kept going but only just, surrounded by 32 ton HGV's all blasting horns, I was getting quite worried. Just managed to cut across 3 lanes into the services, phew!
    RAC chap plugged the laptop in and found fault codes: P0087 Fuel rail/system pressure too low.
    P2263 turbo supercharge boost performance
    P250A engine oil level sensor circuit.
    D00C unknown.
    So, RAC guy figured it was fuel pressure fault, cleared code, lifted back seat and checked pump connections on the in-tank pump (looked all good) and ran it up, fault cleared. But he was concerned and advised I take it to be rechecked, ably assisted by my wife, who was giving me serious looks for having bought a dodgy motor that might get us killed on the motorway.
    The car was dropped off at a repairer for a look over Monday.
    The RAC man reckoned a known issue about pump connections but I find no trace on here.
    Could any of you here with a wealth of experience offer any advice?
    I don't know how long this motor has sat around in dealers, but I drove it a few days before and it was well warmed up and performance was fine, went like a rocket. Fuel level was low but not fume sniffing level on picking it up.
    I fear for the health of my wallet here as the AA 3 month warranty may not be worth the paper.
    Any thoughts?
    Peter
    Senior Member idrobbo's Avatar
    Cheddar
    Given the fuel level had run low it could be a problem with the fuel filter, I have heard of that triggering the RP. Also, as you have just bought it from a dealer, I would approach them first to resolve, they are responsible under Consumer Rights Act 2015 for any problems in first 6 months.
    3.0D 2012 (62) XF-S Premium Luxury IRR
    Previous: 3.0D 2009 (59) XF Luxury, 2002 (52) S Type 3.0 S
    May 2016
    Thanks Rob. The garage I left it with have had a similar conclusion and the AA warranty guys have accepted the costs in full, being as it never made it home. With a bit of luck, collecting it tomorrow and do a bit of testing.
    Next issue is the "low washer fluid" warning which was on. Needs a proper looking over.
    Quote Originally Posted by Petelang View Post
    ... Next issue is the "low washer fluid" warning which was on. Needs a proper looking over.
    On mine (admittedly an XJ, not an XF) this is the only warning that I have successfully managed to resolve by myself!
    Chris. T.
    2000 XK8 4.0 Coupe
    2010 XJ SWB 3.0D Portfolio. With TVs. Lots of TVs.
    Nov 2008
    Hampshire
    Thread moved to X250 XF section.
    Current Car:
    Previous Cars:
    2000 S-Type 3.0L SE Auto
    2007 XK x150 4.2L Coupe
    Resident Super Moderator.
    Senior Member Poundy's Avatar
    Oct 2013
    Alvechurch
    If there is fluid in it and this warning light is still on, I would check the C5 terminal on the CJB for water ingress, could be the start of a bigger problem. Have a read here http://www.jaguarforum.com/showthread.php?t=95802
    64 Plate RSport 3.0D All Black, Ceramic coated, self healing front car wrap, 19" alloys
    Quote Originally Posted by Poundy View Post
    Aha. I hadn't realised that may be an issue. When I got the warning, I just put some washer fluid into the tank and the error went away.
    Chris. T.
    2000 XK8 4.0 Coupe
  8. Likes Poundy liked this post
  9. #8
    May 2016
    Hi Mac. Thank you for responding. I've read about this CJB, but where exactly is it? 7i have just got the car home today for the first time. The washer level wng was on and I put some fluid in. Plan to get my regular garage to have the wing guards off for a look see shortly. Apparently, diesel filter was quite mucky so may have been cause.
    Also today, reverse camera packed in and there's a problem with the left rear door lock. Looks like I've got the full catalogue of known XF woes in this one!
    Peter
  10. #9
    Oct 2013
    Alvechurch
    The CJB is in the right side drivers footwell under the cover, the problem connector is the top left one C5. If you can pull the connector and check inside the bottom of the socket for moisture/corrosion. Really needs the trim off to see properly but it is doable without with a bit of finess and a mobile phone pic of the inside
  11. #10
    May 2016
    I'll be on the case tomorrow. Thanks for the advice guys. Much appreciated.
    Peter
Tags for this Thread
