Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: faulty acceleration with no fault codes
    Morning everybody can you help? Jaguar s type 3.0 v6 auto year aug 2000. notes on last MOT was steering column worn.
    last November on the way to work car was faltering on initial acceleration. as soon as cruising a 20+mph and above seemed OK. left it at home a couple of days and has been sound since. last week from start it was not accelerating and finally cut out. called out trusty RAC who didn't have a clue because it started and showed no fault code but would not rev smoothly. RAC rep suggested I try to drive it home with him following. very tricky getting acceleration but again when travelling at 20 plus OK. just on take off. strange but as we traveled further it got slightly better
    still no fault codes.
    only common denominators
    1.for the last year when filling petrol pump keeps cutting out can take upto twenty mins to get tank filled.
    2. both days it has been playing up pouring with rain.
    Rums
    Wiltshire
    Hi rums,
    You might want to put/move this to the S Type forums here
    Nov 2008
    Hampshire
    Welcome to the forum!
    Thread moved to S-Type section.
    Current Car:
    Previous Cars:
    2000 S-Type 3.0L SE Auto
    2007 XK x150 4.2L Coupe
    Resident Super Moderator.
    Jun 2013
    The reason your fuel tank isn't filling normally is because they are now filtered systems and your EVAP system or its charcoal filter is blocked.
    See this:
    https://www.jaguarforum.com/showthread.php?t=113405
    Replace your fuel filter too if it's not been replaced in the last couple of years, mine was full of mucky brown stuff.
  5. Thanks rums thanked for this post
    Likes S-Type Owner liked this post
  6. #5
    Thanks I've been looking at this forum for sometime and the threads are very helpful. don't know if i will be much help to others at the moment, as my learning curve is somewhat slower than most, but really enjoying getting to know my tools again. After not having the time to maintain my own vehicles for years, its interesting to say the least, without doubt the mind is willing, not sure how the body will hold up. I will check the evap system this weekend I do have a workshop manual but if their is a link to id easier would appreciate a nudge, are their possibilities this could cause the faltering as well?
  7. #6
    Apr 2016
    Near Berlin
    Do you have a bias scanner such as an elm327 so that you can look at the fuel trims.
    Grumpy Old Git
    Napoléon Bonaparte
  8. Thanks rums thanked for this post
  9. #7
    hello again ducmon you've helped me before. yes i do, great idea. will have a go and let you know results. Thanks.
  10. #8
    did scans on elm 327 and my ad410 got no error codes to start and then mass air flow p0102
    I haven't worked out how to do fuel trims yet but I've found an earlier thread that instructs hoe to get a reading. will look at it tonight and get 1 tomorrow.
    Looking to decipher the code now but if anyone can help?
    oh and it started fine and run ok but when it warmed up started faltering and cut out, restarted but continually cuts out now.
  11. #9
    Apr 2016
    Near Berlin
    Of you follow this link
    http://jagrepair.com/images/AutoRepa...os/PE20001.PDF
    It will tell you this.
    Restricted air filter
    MAF Sensor to PCM sensing circuit: high resistance, open circuit or intermittent short circuit to ground
    MAF Sensor supply circuit open circuit or short circuit to ground
    MAF Sensor failure
    If you need the early workshop manual
    Go here
    https://www.jaguarforum.com/showthread.php?t=112645
    Grumpy Old Git
    Napoléon Bonaparte
  12. Thanks rums thanked for this post
  13. #10
    Thanks ducmon, i don't think it is a just as a simple as a faulty MAF sensor, I will start their but i'm fully expecting a really great adventure, this old girl is bringing back to life an old passion.. I'm going to study fuel trims today and get some readings. i will get to this at the weekend. In the meantime, my autodoc app keeps asking me to update to pro which includes fuel trims i guess their will be a cost to this what one do you use?
    I also have the ancel ad410 which will give me fuel triims but the screen is so small I might not be able to read clearly.
