Results 1 to 10 of 12
Thread: Caliper spreader?
    May 2007
    Ashford, Middlesex
    Caliper spreader?
    I have a sticky rear caliper (more in my ownership thread in a bit!), so need to order what I need to have a look at it this weekend. I don't have a caliper spreader or rewind tool though (I can back off the electronic handbrake with the iCarSoft just fine, but thinking I may need to 'exercise' pistons a bit -- would I need a tool?
    May 2007
    Ashford, Middlesex
    I kinda had to move on this, so have ordered this -https://www.amazon.co.uk/gp/product/B073TX99BN/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
    Apr 2017
    Milton Keynes
    Quote Originally Posted by fat controller View Post
    I've got a similar set, i don't how they can manufacture and dispatch in a molded case and actually make any money.
    It is generally the sliders that cause the binding / pulling to one side or the last person not putting the pads in flat on the piston.
    The sliders are different top and bottom, take note when removing so they go back in the correct way.
    Only lubricate these with lithium grease. Copper slip, other oils and greases will swell the rubber and go tight.
    2009 , X358 LWB , 2.7 TtcrdiV6 , Liquid Silver
  4. Likes fat controller liked this post
    Senior Member rchiv's Avatar
    Feb 2013
    Orpington, Kent
    Well that will do just about every car. I bought one of these some years back https://www.ebay.co.uk/itm/SUPER-SAV...UAAOSwPcVVsPbX
    2006 X Type 2.2d SE Manual Estate. Zircon Blue Champagne/Mocca, F/R Parking sensors, ,Auto Lights, Auto Wipers, Headlight Washers, Sat Nav 2012 update, 17 in Wheels, 120K Mods:- Electric Autofold Mirrors on Locking
  6. Thanks Jimbov8 thanked for this post
    Likes Jimbov8, fat controller liked this post
  7. #5
    May 2007
    Ashford, Middlesex
    Quote Originally Posted by FastEddie View Post
    Oh bollocks, I have ordered ceramic grease and red rubber grease - are these no good?
  8. #6
    Feb 2013
    Orpington, Kent
    I believe you should only use synthetic grease on the slide pins. Lithium is petroleum based.
  9. Likes fat controller liked this post
  10. #7
    May 2007
    Ashford, Middlesex
  11. #8
    Apr 2017
    Milton Keynes
    Quote Originally Posted by rchiv View Post
    I have a rather old tin of Lucas, Lithium slider grease that has done well for years.
    On this tin it advises not to use other oils and greases.
    WD40 is the worst, unless you are trying to get an extra days life out of a pneumatic cylinder with worn seals.
    Silicon grease looks to be ok as are many others i would think ..... could be like the ZF LG6 debate lol
    https://www.greaseexpert.com/brake-g...vs-anti-seize/
    https://mechanics.stackexchange.com/...ke-lube-to-use
  12. #9
    Feb 2013
    Orpington, Kent
    You use that on the reverse of the pads to eliminate brake squeal. I would not use it on slider pins.
    I use the grease that comes with CV joint boots.
  13. Likes fat controller liked this post
  14. #10
    May 2007
    Ashford, Middlesex
    Which I am hoping is this one? https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
    Sorry to bombard you with questions
