Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Views on tyre replacement.
    Feb 2011
    Mid Wales
    So my 2010 (my), 3.0 S D, will soon be due a new set of rubber.
    When I first bought the car over 3 years ago I immediately fitted a set of SP Sport,
    245/40R 19, as recommended by Jaguar.
    They have done 17000 miles mostly long fast journeys, not screeching around corners.
    Myself and passengers have always been happy with ride quality.
    I could probably get a few more thousand miles out of them, but safety is my overall priority.
    Nevertheless over the past few years I have noticed negative comments on this forum about these tyres, and never understood quite why.
    However I am happy to listen to any views you may have by personal experience.
    Checking prices correct tyres seem to be in the £140 to £170 range per corner.
    Wirral, Merseyside
    Hi, the Dunlops went through a patch of splits appearing on the inside walls, so much so that they were being replaced FOC by Dunlop, I have no idea if this is now a past problem or not. I have used the Goodyear Eagle F1 Asymetric 3 "J" rated for some years now and find them exceptional, especially in the wet, they are also rated at 67db, one of the quietest on the market, but the "J" is the most important bit, the ordinary Eagle F1's are rated at 69db so it's easy to see the correct ones. Phil
  3. Likes JimC64, Poundy liked this post
    Hi Lenticular, I don't have an XF but an XJ X351, previously an XJ X358 and have covered many miles over these past 25 years, around 1.6M to date
    I've had so many Pirelli / Michelin / Bridgestone, Conti's etc and they're not always what they're cracked up to be, but very expensive and you can be paying for the big brand name
    I'm fairly sure the Dunlops you mention are the ones that have been splitting / delaminating all over the place, but please double check by all means
    Here's a few comparisons for you below, using Blackcircles where you can buy online and have them fitted at a centre near to you
    Dunlop SP Sport 245/45/20 wet B / fuel C / noise 72db £149.41 each, total £597.64
    Kumho Ecsta PS71 245/45/20 wet A / fuel E / noise 72db £131.82 each, total £527.28 LESS £20.00 promo £507.28
    Avon ZZ5 245/45/20 wet A / fuel E / noise 70db £119.58 each, total £479.82
    The Dunlops aren't even offering the best grip in the wet ( which is where you want it living in the UK )
    The Kumho's and the Avons outperform the Dunlops in every area except fuel economy. I've had around 4 or 5 sets of Kumho's on my X351 / X351 and previous to that my Audi A6.
    A really good tyre that performs well, does what it says it does and lasts too, I highly recommend this so called "mid range" tyre
    The Avon's are fantastic too, currently have a set on our X type, been on about a year, no dramas and lasting very well
    Hope to hear what you decide and which way you go
    All my best
  5. Likes N/A liked this post
    Feb 2011
    Mid Wales
    Thanks for your input so far.
    Just noticed that Pirelli P Zero tyres are priced well and see according to KwikFit that they are listed as Jaguar OE.
    But for which model?
    I have a soft spot for Pirelli as when I bought my first cars in the 60's I always went for Cinturatos and they always served me well, even skidding around in my Mk 1 Spitfire !
  7. Likes JimC64 liked this post
  8. #5
    Quote Originally Posted by Lenticular View Post
    I used to be a big fan of Pirelli back in the day and had any a set on my cars, got tyres but they're soft and wear quite quickly I found
    The Pirelli P Zero 245/45/20 is wet B / fuel C / noise 72db £147.83 each, total £591.32
    They will be worse in the wet than the Kumho's and the Avons and are also a noisier tyre
    Just as an aside and I'm sure you probably already know this, The Jaguar OE fitment is nothing more a recommendation period, a tyre with the same specs / sizes etc will do just fine. In fact OE manufacturers make deals with the tyre manufacturers to take hundreds of thousands of tyres from them at discounted prices in return for making them OE fitment. This will often persuade future owners to stick with them down the line and help top increase sales
  9. Likes GeoffR liked this post
  10. #6
    Senior Member Neilr's Avatar
    Jan 2007
    Germany
    A couple of things to remember - very few people start threads on forums on how normal a tyre has performed. Search for problems with any tyre brand and you will find similar reports.
    The other point is that the EU ratings are exceptionally vague not particularly comparable between manufacturers. One manufacturer's wet A seems to test like another manufacturer's wet C. A tyre that is labeled quiet is often not the quietest tyre on test! Let a manufacturer do their own tests and you get interesting results!!!
    Look at some independent tests to see how tyres actually compare under the same conditions. For example, http://www.tyrereviews.co.uk/Article...-Tyre-Test.htm
    Just out of interest compare the Dunlop with the Avon. Officially:
    Avon ZV7 RR: C WG: A Noise: 70
    Dunlop Sport Maxx RT2 RR: C WG: A Noise: 68
    So on paper very close.
    But in the test, the Dunlop was very good. The Avon came in 10th.
    Proof enough that the EU labels are not much of a guide of anything at all
    Btw, I only found one mention of the ZZ5 and it came 9th out of 10 in an AutoSport test in 2014.
    The top brands might be a bit more expensive, but they generally seem to perform a bit better too giving you a little more margin should anything go awry.
    EDIT: A tyre that is testing consistently well but is still cheaper than the famous brands is the Hankook Ventus Prime 3 K125. There seems to be no real trade off with that tyre. Note the top two in this test and compare with the last one: http://www.tyrereviews.co.uk/Article...-Tyre-Test.htm
  11. #7
    Senior Member Poundy's Avatar
    Oct 2013
    Alvechurch
    Like Philayl1 I have replaced my 19" Dunlops with the Jag rated Goodyear F1 Asymmetric 3, I am well pleased with them and been in the habit of fitting them on all our cars in recent years.
    MY15 X250, XF R-Sport 3.0D Black Pack, Ceramic coated, 19" alloys SOLD!
  12. #8
    Senior Member eltel1947's Avatar
    Dec 2010
    Lancashire
    Quote Originally Posted by Poundy View Post
    Would 100% agree with that, excellent tyres.
    Jaguar 3.0 P.L. Sportbrake, Black with all black interior.
  13. #9
    Senior Member Rowley_1812's Avatar
    Dec 2014
    Jct 6 M25
    The Goodyears are looking popular ...
    Over the years when I was doing big annual mileage I experimented with different tyre makes but always found myself returning to Goodyear for longevity, reliability, good cornering and great grip in the wet.
    I too now have a set of Eagle F1 Asymmetric 3's which I swear by but I see that in your size there is a brand new Asymmetric 5 slightly discounted through Blackcircles @ £143.22 per corner (fitted) whereas the Asymmetric 3's come in at £149.46. The 5's do list as being slightly noisier though (72dB as opposed to 69dB).
    Happy tyre hunting!
    2005 (55) X-type 2.0d S saloon ~ Zircon/Champagne/Belize.
  14. #10
    SE London/Kent
    Have a look at Michelin PS4's, as they're not much more than the GY F1 assy 3's & a better tyre.
    You might also look at Hankook. I've run their S1 evo 2 & V12 evo 2 they're both very good + can be had cheaper if you shop around.
    I like Pirellis but find they take a while to warm up go 'off' near the end of life (tread depth).
    ATM I've got GY F1 assy 3's all round on the XF S & PS4's on the STR.
