Page 1 of 13 1234511 ... LastLast
Results 1 to 10 of 129
Thread: Air Suspension Module Ground Point/Stud
    Senior Member EsRay's Avatar
    Oct 2018
    UAE/Dubai
    Dear Forum,
    Please can anyone help?
    I have been searching for the ground stud for the ASM (see G17 below). I have pulled my back seats out and it does not appear to be under there. I have pulled up the carpet and not there either? I have pulled up the grey plastic trim by the rear door-plate and there is a massive wiring loom there but no ground stud?
Name:	C2304 - Ground Points.jpg
  2. Thanks 1955davidr thanked for this post
    Senior Member rchiv's Avatar
    Feb 2013
    Orpington, Kent
    Hi, just a quick question, why do you need to find the ground point as the diagrams show quite a few items use that point. What age is your car. I do not know where it is but I am wondering if it could be on the seat support. There should be quite a few Black leads in that harness under the foot plate which would branch out.
    Please update your signature via the link below for future reference.
    2006 X Type 2.2d SE Manual Estate. Zircon Blue Champagne/Mocca, F/R Parking sensors, ,Auto Lights, Auto Wipers, Headlight Washers, Sat Nav 2012 update, 17 in Wheels, 122K Mods:- Electric Autofold Mirrors on Locking
    Oct 2018
    UAE/Dubai
    Quote Originally Posted by rchiv View Post
    Please update your signature via the link below for future reference. Roger
    Roger, Thank you.
    see post https://www.jaguarforum.com/showthread.php?t=115973&p=1199089 ….#5 & #6
    2005 XJ8L
    LHD
    165,000 kilometres
  5. Thanks rchiv thanked for this post
    Feb 2013
    Orpington, Kent
    Got it. In that case you need to go from the module. Pick up the Black lead and check it for continuity to earth. You can do this without needing to find the stud.
    If there is no fault found you could do a hard battery reset which will reset the module.
  7. Thanks EsRay thanked for this post
  8. #5
    Oct 2018
    UAE/Dubai
    Got it. In that case you need to go from the module. Pick up the Black lead and check it for continuity to earth. You can do this without needing to find the stud. Roger
    Hello Roger. The only pin on the ASM with a black wire (see post https://www.jaguarforum.com/showthread.php?t=115973&p=1199089....#5) is CR88 pin 3. Is that the Earth, please?
    UPDATE: Roger, I think (with your help) I may have answered my own question:
Name:	ASM Ground.jpg
    2005 XJ8L
    LHD
    165,000 kilometres
    Feb 2013
    Orpington, Kent
    That's the one
  10. Thanks EsRay thanked for this post
    Likes EsRay liked this post
  11. #7
    Oct 2018
    UAE/Dubai
    That's the one
    Thanks Roger. Gonna check this ground tomorrow. I tried a hard reset and it made no difference to the CATS System Fault light. I don't expect checking the ground is going to achieve anything either, because both front shocks are passing the pinpoint tests and they must share this ground? I do not have ANY Actuator Failure DTC's...My suspension feels fine...unchanged...This is beyond frustrating!!
    2005 XJ8L
    LHD
    165,000 kilometres
  12. #8
    Feb 2013
    Orpington, Kent
    Have you checked the connector TL93 the 8way black connector below the rear center consol pin 10 is the - and pin 9 +.
    FIG 05.3
  13. Thanks EsRay thanked for this post
  14. #9
    Oct 2018
    UAE/Dubai
    FIG 05.3 Roger
    Cannot see a pin 9 (2005 XJ8L wiring diagram)?
    Pins 7,2,8 & 11 appear to refer to the rear Damper Actuators? What am I checking for here please Roger? Ohms? Volts? Continuity? (please excuse may lack of auto-electrical knowledge...I am out of my depth here)?
    2005 XJ8L
    LHD
    165,000 kilometres
  15. #10
    Feb 2013
    Orpington, Kent
    Look carefully at the diagram. Find pins 7 and 2 and follow the lines you will see that they go to TL93 which is the connector I am talking about. They go through this joint before going to the actuator. Pins 8 and 11 go direct to the actuator. I hope you see what I mean. If there is a dodgy or dirt connection here it could be your problem. If you go up one page you will see the location of all modules and connectors.
  16. Thanks EsRay thanked for this post
