Results 1 to 10 of 53
Thread: No sensors working - iCarsoft LR v2 diagnostics
    Jan 2012
    Hampshire
    So after years or no parking sensors, I finally decided to look into it and have acquired (2nd hand from bertster, thanks) a iCarsoft LR v2.
    All my sensors report "Sensor distance 0.10 inch".
    Does this mean the control module is knackered?
    [img]imgur.com/nFmR5cm[/img]
    2005 Ultra Violet S-Type R (STR) 196,000 miles.
    Senior Member Andy K's Avatar
    Oct 2008
    UK
    What do the fault codes say for Parking discltance control
    Jun 2013
    Not necessarily, because one shorted sensor can affect the rest.
    If there are no codes I think you'll need to disconnect the sensors one by one, or replace them one by one.
    Jan 2012
    Hampshire
    I cant work out how to link/embed the images correctly, so I'll copy them out manually;
    Front left inner sensor distance: 0.10 inch
    Front left outer sensor distance: 0.10 inch
    Front right inner sensor distance: 0.10 inch
    Front right outer sensor distance: 0.10 inch
    Front left inner sensor detection flags: Detected
    Front left outer sensor detection flags: Detected
    Front right inner sensor detection flags: Detected
    Front right outer sensor detection flags: Detected
    Parking aid activation speed threshold: Above Threshold
    Parking aid de Activation speed threshold: Above Threshold
    Front sounder status: Inactive
    Control module status: Operational mode
    Mute status: Inactive
    Number of permanent diagnostic trouble codes: 2
    Front sensors status: Inactive
    Rear sensors status: Inactive
    System status: Inactive
    Rear sounder status: Inactive
    Rear left inner sensor distance: 0.10 inch
    Rear left outer sensor distance: 0.10 inch
    Rear right inner sensor distance: 0.10 inch
    Rear right outer sensor distance: 0.10 inch
    Rear left inner sensor detection flags: Detected
    Rear left outer sensor detection flags: Detected
    Rear right inner sensor detection flags: Detected
    Rear right outer sensor detection flags: Detected
    Front parking aid system disable switch: OFF
    System LED: Inactive
    Trailer attached: NO
    Transmission in reverse: YES
    Jan 2012
    Hampshire
    I am guessing the 2 'above threshold' speed threshold messages = something is borked? And will this be causing the 2 'sensor status inactive', or vice versa?
    Oct 2008
    UK
    Humm.
    Days there are 2 codes. What are they.
    Jan 2012
    Hampshire
    It says 2 codes, but when I select the 'Show Fault Codes' it displays none.
    Jul 2009
    Yorkshire
    Perhaps they are the ones described as Above Threshold
    Senior Member Marcuspd's Avatar
    Aug 2018
    UK/ Ashford, Kent
    Pop the connector off the module and look for blue corrosion on the pins and connector. You could also pop the mounting nuts off and remove the module.
    Pop the cover off and look for water damage.
    It's quick to do and a cheap fix if the module has suffered the common water damage issue. Water seems to wick up the cable and end up on the circuit board, frying components. This was my fault giving no working sensors and a £25 fix for a tested, used module from UK's Autoreserve Jaguar.
    Jaguar S Type 3.0 V6 Sport 2001.
    Jan 2012
    Hampshire
    Quote Originally Posted by Marcuspd View Post
    I did post a pic of the board here <https://www.jaguarforum.com/showthread.php?t=117083>. There is some white gunk (which I have cleaned with electrical cleaner), but the pins and everything else looked perfect.
    Basically I want to make sure there is nothing else that could be wrong before buying ANOTHER module off eBay. I had a quote of £141.89 +VAT (£170 total) for a new one from Jaguar.
