Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Pre-MOT problem
    May 2013
    Pre-MOT problem
    Would like advice on what possible fault might be please.
    My Jag has been used once for a short journey every 7-10 days throughout virus lockdown, so my car has been sitting for quite long periods, and its' MOT is due in a week or so. When I used it yesterday my engine warning light, ABS/TSC lights all came on. When I got home I was unable to lock the car with the fob, but ok with the key in the door. Prior to this my car performed faultlessly, when it was used almost daily. The battery is only 4 years old (Varta 019), but I have no means of testing voltage, and after the fuss from the last time I replaced it (resets, etc) I am reluctant to remove it from the car. I had slightly similar things happen last time the battery died, although the car completely shut down back then. There are no fault codes.
    Is it more likely to just need recharging after standing still for so long, if so I'll just have to bite the bullet and do all the resets again?
    2003 S-Type 3.0 SE Auto
    Senior Member payno's Avatar
    birmingham
    You can charge the battery while its still in the car and you will not need to MOT your car until November because of this virus that s doing the rounds
    S TYPE R 2003
    BMW M3 EVOLUTION 1998
  3. Likes Jimbov8 liked this post
    May 2013
    Thanks for the quick answer!
    Is it safe to recharge it while still connected to the car, as I thought I'd read somewhere it had to be removed?
    birmingham
    There are many members on here that keep there Jaguar batteries topped up this way in a few hours there will be a few more posts by other members to confirm this You can buy chargers now that use a quick connect disconnect lead that fixes into the car so you can plug a flying lead from the charger in and walk away
    S TYPE R 2003
  6. Thanks Gaz03SE thanked for this post
  7. #5
    May 2013
    Thanks. I have a charger with a quick connect lead for my motorbike but not sure if it's suitable for cars. Might invest in a Ctek MXS 5.0 that I've read about on here.
  8. #6
    Jul 2009
    Yorkshire
    I've charged my battery still connected without hassle. I connect the charger whilst it's off then turn it on. Similarly, turn it off before disconnecting the leads - all done to reduce any risk of sparks / surges.
  9. Thanks Gaz03SE thanked for this post
    Likes Irish Pappy liked this post
  10. #7
    birmingham
    Sounds like a plan that will work
    S TYPE R 2003
  11. Likes Gaz03SE liked this post
  12. #8
    Senior Member Rowley_1812's Avatar
    Dec 2014
    Jct 6 M25
    Quote Originally Posted by Gaz03SE View Post
    That should do the trick Gaz, the CTEK MXS 5.0 is a good piece of kit but do read the small print and be sure to connect the positive to the battery and the negative to an earth point on the car and NOT the battery negative. Although it might not properly explain it's to do with a potentially adverse effect on the car's electrics/ecu etc. apparently ... best to be on the safe side eh?
    2005 (55) X-type 2.0d S saloon ~ Zircon/Champagne/Belize.
  13. Thanks Gaz03SE thanked for this post
  14. #9
    May 2013
    Will try not to blow myself up!!!!
  15. #10
    May 2013
    Rowley, won't the quick connect lead be connected to positive & negative terminals? Have ordered a Ctek so will have a read when it arrives.
