Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Petrol or diesel?
    May 2020
    Sweden
    Petrol or diesel?
    Hello guys!
    Im looking at buying an XF later this year or next year, been looking around alot and they're pretty cheap now
    But I dont know wether I should get a petrol or a diesel?
    I have about 9.3 miles to work, and it's highway almost all the way!
    THe diesels are cheaper and easier to come by, but some have said I should avoid them?
    So what do you guys think?
  2. Thanks V8Steve thanked for this post
    Likes Robinus liked this post
    Senior Member Henry_B's Avatar
    Oct 2016
    Hereford,Uk
    I prefer the Diesel myself
    Suits the cars character...
    MY2005 Jaguar S Type 3.0SE Radiance red / Champagne - High Luxury - + Celtic Stage 1 - 268hp - 232 LB-FT
    ( ಠ ͜ʖಠ) ¯\_( ͡° ͜ʖ ͡°)_/¯ ( ͡~ ͜ʖ ͡°)
    Senior Member barryhi's Avatar
    Mar 2016
    Norfolk
    Petrol every time unless fuel cost is important to you.
    Currently: 2010 XF 3.0 Petrol - Premium Luxury
    S-Type 3.0 SE 2007
    S-Type 3.0 Sport Auto 2004
    S-Type Spirit 2.7D Auto 2007
    S-Type 2.5 SE Auto 2004
    2 x 2.1 X-Type SE
    2 x Xj6 (1 x 4.2 litre & 1 x 3.4 Litre)
    Daimler 2.8 Litre
    Aug 2017
    Woking
    Hi Sarah
    I have the diesel due the amount of miles I do a day (60) but do prefer the petrol.
    I think if you only do 9 miles a day you might encounter some issues with the DPF if you went for the diesel, however it would save you money on fuel in the long run
    XF 2.0 R Sport 68 plate, white and lots of toys
    XF 2.2D R Sport 65 plate and black (of course) and loving the ride
  6. #5
    Senior Member payno's Avatar
    birmingham
    Quote Originally Posted by taffyhornblower View Post
    Hi Sarah
    Having a problem with the DPF could easily wipe out the fuel savings
    S TYPE R 2003
    BMW M3 EVOLUTION 1998
  7. Likes taffyhornblower, Jimbov8 liked this post
  8. #6
    May 2020
    Sweden
    I see
    Is the DPF easy to change yourself (like oilfilter and airfilter on most cars) or does a mechanic have to do it? Expensive?
    Other than that, are there issues with the diesels and the petrols? Like, are there certain issues with the petrol and with the diesel? Avoid highmilage or go for them?
    The diesels here are ALOT cheaper and also ALOT more common, but I know getting a diesel for short commutes is generally pretty bad
    Thanks for the replies guys!
  9. #7
    Jun 2009
    Manchester UK
    The diesel engine and year in question may help get a more accurate answer.
    In general diesel engines don't like short journeys because they don't get chance to warm up properly. This causes a few issues:
    EGR valves get clogged up.
    DPF's don't get chance to regenerate and clean themselves.
    Later engine designs cope with these issues better than earlier ones, which may have been retrofitted with the emissions technology. These issues are not Jaguar specific, most manufacturers suffer with the same problems.
    I'd say the car needs to stretch its legs once a week for something like 20 mins of highway driving (50mph+) in one go, without this you may have issues with the DPF and would be better off with a petrol car. Note; all new cars need particulate filters now but I haven't heard of the petrol ones causing an issue yet.
    If a DPF needs changing it would require a mechanic and cost over £1k at least.
  10. #8
    birmingham
    Its part of the exhaust system and quit expensive to replace
    Avoid high mileage or go for them?
    Modern cars are made to do high miles but as with any car lower is better
    Swings and runabouts you pay more for the petrol but when you sell it you get more back
    S TYPE R 2003
  11. Likes Sarah Holmgren, Robinus liked this post
  12. #9
    May 2020
    Sweden
    Sounds to me I should aim for a petrol one then
    Year doesn't matter to me, the facelifted one looks better than the prefacelift one, but both look alot better than what I currently drive, and I gotta say, the XF has aged well in my eyes
    So, pricewise the one from 2007 up until 2010 is the cheaper option, there are some that has done less than 100k for an affordable price, but is there something else I should look out for? Does the petrol engine have a timing belt or chain? Any specific issues that are common on these engines etc?
  13. #10
    Jun 2009
    Manchester UK
    Once you've been able to narrow it down, then it's a lot easier to give you the specific what to look for things.
    I think all the petrol engines are timing chains. The early 5.0 V8s suffer from timing chain issues until 2014ish. The 4.2s V8s are very robust.
    I don't think the petrol engines cause many headaches. I'm sure others will add more things to look for.
    Check for any signs of water in the boot, plays havoc with the electrics.
    Some XFs had an issue with water ingress from the washer pump (only a specific year or two).
    Your in Sweden, so check underneath for rust on the subframes.
  14. Likes Sarah Holmgren liked this post
