Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 75
Thread: Help! Loads of error codes
    Jun 2020
    Came out to the car to go to shops and decided to check fuel trims
    Plugged the i930 in and all of a sudden all of the error codes under the sun popped up
    The car won't start, keeps telling me loads of codes are valid and I can hear a really weird almost gurgling noise from under the bonnet on the passengers side
    The csr eventually did start, but won't go into gear
    Have I duffed the battery somehow by plugging the i930!?
    Jul 2009
    Yorkshire
    Doubt it. Sounds like a flat battery.
    Jun 2020
    Yeah just weird that the car was running fine, plugged the obd in and then all of the warnings came up one after one on the dash!!
    Maybe shorted it temporarily?
    Its fine now and got to the shops and back with no issues!
    Apr 2016
    Near Berlin
    Dont forget that icarsoft has no power supply of its own, this could mean that when you connected it. You used the last of the available spare voltage.
    This then mean that you would start throwing up lots of codes.
    Jun 2020
    Which would suggest the battery is on last legs?
    I'm sure that I looked at the battery stats on the i930 and it was at full voltage though
    Jun 2020
    Weird, went out again, car was on this time, no problems
    Plugged the obd in, it stayed on for about a minute then powered off and loads of error codes came up on the dash agaon!!!
    Battery must be on its last legs if just powering the obd stresses it or am I doing something wrong!?
    Apr 2016
    Near Berlin
    Try it when the car is running, but on mine i can keep on working on the car for around half an hour.
    So I would suspect your battery
    Jun 2020
    Well got battery tested and it was only outputting about 60pc of the power
    So hopefully that was my problem!
    Bought new battery from the shop and will change over later
    Take it for the s type its as simple as negative off, positive off and refit new one the other way round?
    If I want my fuel trims to reset, this will mean that will happen too?
    Apr 2016
    Near Berlin
    Quote Originally Posted by Millertime View Post
    Charge the new battery before you put it. Make sure you have the radio code. Don't know about the fuel trims but why do you want them to reset?
    Jun 2020
    Just so that since I have fixed my air intake hose now then I will get an accurate fuel trim reading so I know what the car is doing with fuel air ratio?
