Results 1 to 8 of 8
Thread: 1961 Mark 2 Gearbox overheating
    Jul 2020
    Eye Suffolk
    Hi I have just bought a mark 2 1961. The gearbox which was rebuilt last year gets very hot very quickly-also the overdrive is a bit clunky when disengaging-any ideas?
    Apr 2008
    Further up the creek.
    Sounds like the wrong type of oil in the gearbox.
    Now please check this, for my memory is not what it used to be (!) but (I think) it should be SAE 30 oil for the earlier Moss box and EP90 for the later all-synchro box.
    I think your 1961 example would have a Moss box (but please check, as it may have been changed). So if (for example) your Moss box has been filled with EP90, this could lead to the symptoms described.
    Whatever, first thing to do is identify the box, then drain and refill with the correct oil. Then see how it goes.
    2000 Jaguar X308 4.0
    1973 Jensen Interceptor Mk III 7.2
    1969 Jensen Interceptor Mk I 6.3
  3. Dislikes Zero123 disliked this post
    Jul 2020
    Eye Suffolk
    Thanks for that-local garage have suggested it could be a bad earth so have had this sorted and just need to test it.
    May 2011
    Agree oil is important based on type of gearbox. Re overdrive being ‘clonky’ when disengaging, this is fairly normal if you don’t depress the clutch whilst coming out of overdrive.
    PETER DAVIES, 2016 XF 2.0 diesel Portfolio. 1967 Mark2 (240.)
  6. #5
    Feb 2016
    OSWESTRY, Shropshire
    Hello Peter,
    forgive me but the idea of using a clutch with the overdrive is nonsense. Use the switch, that is all that is needed.
    As a general view of the original post, it's unusual for the disengagement to be a problem. Common problems are lack of engagement, usually electrical but sometimes due to worn clutches.
    Alec
    MK 2 3.8 (Long term restoration), 2.5 P.I. Triumph saloon, 564 Hymer motorhome.
  7. #6
    May 2011
    Alec,
    I’ve had my 240 over thirty years and have always found that if you change down from overdrive to direct at higher speeds there is a definite jerk as the switch engages and increases the revs. Dipping the clutch makes for a much smoother drive.
    Offered my opinion in good faith. Don’t appreciate it being called nonsense!
  8. #7
    Feb 2016
    Hello Peter,
    I use nonsense literally, I also could have said illogical. Dipping the clutch does nothing to match the car speed, engine speed relative to the gear. Yes, you can slowly engage the clutch and drag engine speed up at the expense of extra clutch wear, although you said dip. A simple increase in engine speed using the throttle is my preferred way and I can easily match your 30 years of overdrive use.
    I apologise for being forthright and meant no offence.
    Alec
  9. #8
    Senior Member cass3958's Avatar
    Jun 2014
    Torquay Devon
    Cannot comment on a Jaguar overdrive as my S type is an Auto but I had an MGB GT V8 with overdrive on a column switch. Going up the overdrive was just a fifth gear. Coming down it was an over taking gear. To change down you put your right foot flat on the floor and flicked the switch and the car would go off like a scalded cat. I was in my twenties and sometime felt like a definite jerk but it put a smile on my face.
    Rob.C.
    1968 Jaguar S Type 3.4 Auto Old English white
    2006 X type SE 2.0d Estate
    1966 Ford Anglia 1760 X flow
    1993 Yamaha FJ1200
    2012 Old English Sheep Dog White and Grey
