Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: My New Motor (2000 S Type 3.0 SE)
    Junior Member Mikkilaw's Avatar
    Sep 2020
    Burton Upon Trent
    I picked up the car a couple of weeks ago. Still getting used to it (driven a couple of hundred miles), and had one or two annoying minor issues, but on the whole it seems like a decent car. Would appreciate any feedback relating to the following:
    Resolved issues:
    Wiper mechanism and motor failed:
    Replaced both and now working fine. From what I've seen elsewhere on this forum, wiper issues are fairly commonplace on these early S Types, as the design leaves much to be desired.
    Wobbly braking: Replaced front brake pads and discs, now absolutely fine.
    Outstanding issues:
    Rear axle / subframe corrosion:
    This has been an advisory for the last two MOTs. I've had an MOT guy look at it and apparently it's nowhere near a fail yet, but I'm keen to try and get something done to contain it and stop the spread.
    DSC System Error: I've seen plenty of posts on here about this, and understand it can be a number of things. When I first picked up the car the light was flashing; a diagnostic test identified a brake sensor which has now been replaced, but the error is now an (almost) constant warning light with the error description in the message centre. I imagine this will take a while to resolve, but the good news is the car drives really well so I'm hoping it's nothing too serious.
    Interior: There is some very minor superficial cracking in the leather on the driver's seat bolster, I understand this can be treated but not sure what products / services are best. It's the very light cream leather, so any imperfections show up very clearly, unfortunately. There are also a couple of stubborn stains on the (original Jaguar) driver's floor mat.
    Bodywork: Generally pretty good for a 20 year old vehicle, but there are a few stone chips on the bonnet, one right next to the grill with visible rust. There's also a scratch on the driver's door mirror, and some slight bubbling (not come through the paint yet) above the O/S passenger door.
    Apr 2015
    Essex
    You are going to need to get the diagnosis code for the DSC fault.
    Please note that low cost pattern part sensors can be a bit of a mixed bag, with some faulty from new!! But the next one in the box will be fine for years!
    It will probably be the same sensor or another, but the rotating rings can get rust under them, expand and then touch the sensor causing it to fail.
    Mellow
    Black 2004 S-Type R
    VIN: 51N141xx (4.75MY)
    First owner 01.03.2004 to 05.11.2004 Jaguar Cars Co. Fleet Admin, Rugby.
    P.D.I done at Browns Lane on 24.02.2004 at 43 miles.
    Body shell dated 12.01.04.
    (Previously Morocco Red/Magnolia 4.0 XJ40 Sovereign VIN:708xxx.)
    Sep 2020
    Burton Upon Trent
    Thanks for the tips! Here's a few pics:
    https://m.facebook.com/john.wortley/...7726068401713/
  4. Likes S-Type Owner liked this post
    Sep 2020
    Burton Upon Trent
ID:	34885Click image for larger version.
ID:	34886Click image for larger version.
ID:	34887Click image for larger version.
ID:	34888Click image for larger version.
ID:	34889Click image for larger version.
ID:	34890Click image for larger version.
ID:	34891Click image for larger version.
ID:	34892Click image for larger version.
ID:	34893Click image for larger version.
ID:	34894Click image for larger version.
ID:	34895Click image for larger version.
ID:	34896Click image for larger version.
ID:	34897Click image for larger version.
ID:	34898Click image for larger version.
  6. #5
    Nov 2012
    Carlisle
    Looks good and clean.
    As mentioned get the codes read for the DSC, or look at getting IDS yourself as it will save money.
    The sub frame, remove any large flakes but don't get to aggressive. then apply a light coat of wax oil.
    The leather, you could just use a good cleaner and feed any brand will do. You can buy pigment kits although they may be a bad match. A local trimmer will respray it for a reasonable sum.
    Rust on panels needs treated sooner rather than later. either perform a localised repair yourself (if it's tiny or in an obscure place) by grinding out the deep rust and using a quality rust stabilisers followed by a primer, topcoat and lacquer (use a artists brush if it's a stone chip. Or get a body shop a chip repair to do it. It may be worth doing a localised repair in the first instance and get a it done professionally in a couple of years when other imperfections start to show up making a who panel job more economical.
    Put the may in the washing machine on 60deg.
    Current Cars
    2005 Galaxy 1.9TDi 130 Zetec - Blue
    2004 Renualt Megan RS 225
    1994 Escort 1.6Efi Solar Cabriolet
    2007 Transit 350-100
    Past Jaguars
  7. Likes Ashanti, Mikkilaw liked this post
  8. #6
    Member ItsHOWmuch?'s Avatar
    Jul 2020
    UK
    Lovely colour!
  9. Likes Mikkilaw liked this post
  10. #7
    Senior Member Victor's Avatar
    Aug 2006
    Dewsbury West Yorkshire
    Interior leather ??
    https://www.liquidleather.co.uk/
    A very cynical grumpy old man
    Late 2004 2.7D auto
    Connoisseur of Fine Ales
  11. Likes Mikkilaw liked this post
  12. #8
    Sep 2020
    Burton Upon Trent
    Quote Originally Posted by ItsHOWmuch? View Post
    Lovely colour!
    Thanks! For some reason, you don't seem to see many in red!
  13. #9
    Senior Member Henry_B's Avatar
    Oct 2016
    Hereford,Uk
    Quote Originally Posted by Mikkilaw View Post
    I like a nice red 'un
    She looks like a smart mota!
    MY2005 Jaguar S Type 3.0SE Radiance red / Barley/Mocha - High Luxury - + Celtic Stage 1 - 268hp - 232 LB-FT
    MY2001 Range Rover P38 Vogue Monte Carlo Blue V8 + Janspeed goodies!
  14. #10
    Nov 2012
    Carlisle
    Quote Originally Posted by Henry_B View Post
    I Think UIn general, red is not a luxury car colour so the quantity built was probably lower than the silvers, and blues..
    Current Cars
    Past Jaguars
  15. Likes Henry_B liked this post
